07-11-2012 01:08 AM - edited 03-07-2019 07:42 AM
I would like to test the possibility to reload devices via SNMP for new switches like 2960, 3560 and so on.
I know that the command "snmp-server system-shutdown" has to be configured, then I need to send the set query to the device via SNMP.
I have found on the net the OID 1.3.6.1.4.1.9.2.9.9.0 but it belongs to an old MIB and doesn't seem to work with new switch models.
Is there someone who knows what OID to use ?
Thanks in advance
Thomas
07-11-2012 02:51 AM
Thanks in advance
Thomas
Hello Thomas,
Normally you need to append a "0" on this OID if you are testing this OID via a simple snmpget queries.
snmpget -Os -v1 -c
Hope to Help !!
Ganesh
07-11-2012 06:10 AM
Hello Ganesh,
Thanks for your reply however it is not what I would like to do.
The OID you gave (1.3.6.1.4.1.9.2.1.2.0) corresponds if I'm not wrong to a "whyReload" string. Moreover it belongs to OLD Mib which doesn't seem to work on new switches too.
I would like to know the new OID usable in write mode to reload the switch.
Thomas
07-11-2012 06:46 AM
tandlauer wrote:
Hello Ganesh,
Thomas
Check out the below link
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_q_and_a_item09186a00800c263d.shtml#qa4
Hope to Help !!
Ganesh
07-11-2012 08:14 AM
Thanks Ganesh.
I have already tried the method explained in your link, but I get an "invalid OID" response. This OID belongs to the MIB
OLD-CISCO-TS-MIB
To my mind this OLD-CISCO-TS-MIB is not supported anymore on new switches, and I would like to know the new OID to use.
Or maybe I did wrong and it works ? Has someone managed to reload a 2960 for example via SNMP ?
Thomas
12-09-2016 02:16 AM
I am having the same issue. The OLD-CISCO-TS-MIB is unsupported on IOS-XE devices and I am unable to get the new MIB for IOS-XE. Where you able to get a solution of this issue from Cisco ?
02-23-2016 12:38 PM
Thanks Ganesh!!!
From the link above you gave, I got the following:
./snmpset 10.16.99.55 private .1.3.6.1.4.1.9.2.9.9.0 i 2
and used it to reload my 2960S switch.
Thanks.
