One command for DTP,
hi ,
i have 52 port switch 3750. all port are Dynamic auto. if i connect another switch so its make Trunk auto ,  which is not requird for security purpose ,
- i need to know One command or trick which i can disable , DTP in switch and make it more secure,--please answer ,
Jon Marshall
3750(config)# int range gii0/1 - 52
3750(config-if-range)# switchport nonegotiate
you should then set your ports to access ports (except for the trunk links obviously) eg  -
3750(config-if-range)# switchport mode access
Jon
