One way ping 3825 gig port from laptop
I can ping router from my laptop but fails 100% form router to Laptop..
Laptop to router----works fine
Router to Laptop--Fails 100%
I directly connected my laptop to router also tried connected via 3560 switch.Same result..
3825----Laptop connection &
3825---3560--Laptop
I disable windows XP Firewall also disable antivirus on laptop
I also added /32 static route to gig 0/1 and also enable EIGRP but no luck
ip route x.x.x.x 255.255.255.255 gig 0/1
Thanks in advance
Re: One way ping 3825 gig port from laptop
This sound very much to be a firewall issue. You want to investigate further in that direction.
What if you try another laptop?
Have you tried a packet capture on the PC?
Yes its my laptop
I chnaged to another laptop it worked fine
Thanks for your prompt response!!
146
