Only SSH and NO Telnet
mrashby
All,
I have been using telnet for a while now to access my routers now that my routers are configured to use SSH 2 our security group wants us to nix the telnet access all together. As simple as it may be I never have done it. Can anyone instruct me on how to totally turn off telnet on a router. Thanks.
line vty 0 4
transport input ssh
If its a Catalyst then there are 16 vty lines by default so:
line vty 0 15
transport input ssh
Andy
line vty 0 4
transport input ssh
line vty 0 15
transport input ssh
Andy
donlerche
Hi, have just done this using the following commands on the vty's:-
line vty 0 15
transport input ssh
transport output ssh
This should remove the ability to both telnet to and from the device. It appears the default is "transport input telnet" and "transport output telnet" but this doesn't show in the config. If you want BOTH telnet & ssh, then use "transport input telnet ssh" and "transport output telnet ssh"
Don
Ensure that you have the transport output ssh command in there, otherwise if you try to ssh from one device to another it's not going to work.
Thomas
While configuring transport output ssh might be a good idea it is certainly not required. SSH as an output transport is enabled by default. I frequently SSH from one router to another and the router from which I initiate the SSH does not have transport output ssh configured.
But as Don pointed out, if you want to disable outbound telnet then you do need to configure transport output ssh.
That configuration is required to disable telnet, it is not required to enable ssh.
Rick
Rick
