08-05-2014 04:02 AM - edited 03-07-2019 08:16 PM
I am trying to connect two Cisco Nexus 5548UP switches together using GLC-SX-MMD with multimode fiber but link is still down. Set the interface speed to 1000 and swap the SFP to other slot but result is still down. Kindly help me. Output is below
Switch-A# show int ethernet 1/31 brief
Ethernet VLAN Type Mode Status Reason Speed Port
Interface Ch #
Eth1/31 1 eth trunk down Link not connected 1000(D) --
Switch-A# show int ethernet 1/31 capabilities
Ethernet1/31
Model: N5K-C5548UP-SUP
Type (SFP capable): 10Gbase-(unknown)
Speed: 1000,10000
Duplex: full
Trunk encap. type: 802.1Q
Channel: yes
Broadcast suppression: no
Flowcontrol: rx-(off/on),tx-(off/on)
Rate mode: none
QOS scheduling: rx-(6q1t),tx-(1p6q0t)
CoS rewrite: no
ToS rewrite: no
SPAN: yes
UDLD: yes
Link Debounce: yes
Link Debounce Time: yes
MDIX: no
Pvlan Trunk capable: yes
TDR capable: no
FabricPath capable: yes
Port mode: Switched
FEX Fabric: yes
Switch-A# show int ethernet 1/31 cable-diagnostics-tdr
Interface Speed Pair Cable Length Distance to fault Channel Pair Status
Switch-A#
Switch-A# show int ethernet 1/31 transceiver calibrations
Ethernet1/31
transceiver is present
type is SFP-1000BASE-SX
name is CISCO
part number is FTLF8519P3BNL-CS
revision is A
serial number is FNS175111EN
nominal bitrate is 1300 MBit/sec
cisco id is --
cisco extended id number is 4
SFP Internal Calibrations Information
Slope Offset Rx4/Rx3/Rx2/Rx1/Rx0
Temperature 0 0
Voltage 0 0
Current 0 0
Tx Power 0 0
Rx Power 0.0000/0.0000/0.0000/0.0000/0.0000
Ethernet1/31 is down (Link not connected)
Dedicated Interface
Hardware: 1000/10000 Ethernet, address: 002a.6aa3.37c6 (bia 002a.6aa3.37c6)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
reliability 0/255, txload 1/255, rxload 1/255
Encapsulation ARPA
Port mode is trunk
auto-duplex, 1000 Mb/s, media type is 10G
Beacon is turned off
Input flow-control is off, output flow-control is off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
Last link flapped never
Last clearing of "show interface" counters 00:54:36
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
RX
0 unicast packets 98 multicast packets 0 broadcast packets
98 input packets 720 bytes
0 jumbo packets 0 storm suppression bytes
98 runts 0 giants 0 CRC 0 no buffer
98 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
0 unicast packets 0 multicast packets 0 broadcast packets
0 output packets 0 bytes
0 jumbo packets
0 output errors 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
0 interface resets
Switch-A#
08-05-2014 03:57 PM
Duplicate post.
Go here: https://supportforums.cisco.com/discussion/12271676/cisco-nexus-5548up-link-not-connected
