bma
Community Member
optical fiber connection
How many optical fiber connections can make with Cisco 6513 or Cisco 4509 level 3 switch? What is best version for it do HSRP?
ben
Re: optical fiber connection
Ben,
It depends on the number of slots in the chassis that you have. Please see the port density based on the chassis and the modules used on 6500:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_data_sheet0900aecd801459a7.html
This is for Cat4500:
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet0900aecd802109ea.html
All the Cisco IOS supports HSRP. Let us know the IOS that you are running and we will try to suggest accordingly.
HTH,Please rate if it does.
-amit singh
bma
Community Member
Thanks.
We want to buy new switch for new location and not running now. What version do you suggest to us?
Ben
Ben,
What all switches are you buying. let me know the model numbers and will suggest you accordingly.
-amit singh
bma
Community Member
Amit
We will use Cisco 6513 or 4509.
ben
175
