OSPF ABR question
I have router A and Router B connected together.
I have Router C connected to both Router A and Router B in a triangle design.
Router A has a link to Router C. Area 10
Router B has a link to Router C. Area 10
What will be the ABR for Area 10? Where do I summarize the routes for the locally connected networks on Router C?
Please advise.
Hall of Fame Super Bronze
Re: OSPF ABR question
You haven't mentioned any OSPF area other than Area 10. You need 2 OSPF areas in a router to be considered an ABR.
Hall of Fame Super Silver
Sparky
The point made by Edison is very true, that you have mentioned only area 10, and with only a single area defined there is no ABR.
To supplement his response a bit, in the Cisco implementation, it is not enough that a router have interfaces in 2 areas, to be an ABR it is also necessary that the ABR have an interface in area 0. The interface in area 0 can be a physical interface or it can be a virtual link. But a router with intefaces in 2 areas where neither area is area 0 (for example a router with interfaces in area 10 and in area 20) does not function as an ABR.
Rick
hai,
Cheers Rick
Lijesh ....
There is no mention of area between A & B. If they are also in area 10 & you need to create an ABR among the 3, then you may create a loopback on router C & advertise it in area 0. This would make C an ABR & you may summarise local networks of C.
Router A and Router B have a 3 SVI's between them and are in Area 0.
I plan on connecting Router D to Router A and B also to form Area 20.
Is there any reason I should put Router A & B also in area 10? I need a backbone area 0, I thought.
If they plan to be OSPF neighbor with Router C, they need to have Area 10 as well.
Are you coming up with things as the day goes along ? :)
If I understand this correctly, you have a pair of routers - A&B with three logical links between them.
You then have two more routers. C&D. These both link back (dual homed to A&B
A
C ||| D
B
The three links between A&B are area 0 - that is yor backbone. The links to/from C are in area 10 and D area 20.
That makes A&B your ABRs.
A network like this would I hope just be a lab excercise, as there is little point running areas with just 4 routers. The summaristation would be configured on A&B, but all it would acheive would be smaller routing tables on C&D - whatever the summaries are for the "far" area, ans whatever you summarised the three backbone links as.
Ok good to know because I have about 20 different networks on router c and will have about 20 on router D.
example.
So I dont want to have 20 network entries via network C, instead I want it summarized.
166
