Bronze
OSPF and 3660/2924XL
My 3660 is not populating the routing table:
3660 on 12.4.15T2 with 2 FA interface:
10.0.26.100 on FA0/1
10.0.126.1 on FA2/0
I have router ospf 1 with A0 turned on for both interface and confirm with sh ip ospf interface. C6k-Core has full OSPF routing table and I am trying to neighbor up with the c6k-Core.
3660--2924XL---C6k(Access Switch)--C6k(Core Switch)
I can ping the local VLAN26 (10.0.26.x/24) so able to ping/telnet to 2924 and C6k-Core
2924 relevant configs:
Port facing 3660:
switchport access vlan 26
spanning-tree portfast
Port facing C6k-Edge:
switchport multi vlan 26
switchport mode multi
C6k-Edge Relevant configs:
switchport
switchport mode access
Don't think I need to provide c6k-edge to c6k-core as it is working fine for other parts of the network
Hall of Fame Super Bronze
Re: OSPF and 3660/2924XL
Please post show ip ospf interface bri from both OSPF speaking devices.
__
Edison.
Bronze
3660 - Don't worry about Fa 0/1 as I don't have anything attach. I am only concern with F2/0. On the 3660, I was able to telnet to the C6k-core and run the commands
R-WAAS-WAE-CA#sh ip ospf int brie
Interface PID Area IP Address/Mask Cost State Nbrs F/C
Fa0/1 1 0 10.0.126.1/24 1 DOWN 0/0
Fa2/0 1 0 10.0.26.100/24 1 DR 0/0
On the C6k-core
core1#sh ip ospf inter brief
Vl26 1 0 10.0.26.2/24 1 DR 0/0
Vl78 1 0 10.0.78.2/24 1 DR 0/0
Vl68 1 0 10.0.68.2/24 1 DR 0/0
Vl19 1 0 10.0.19.2/24 1 DR 0/0
Vl18 1 0 10.0.18.2/24 1 DR 0/0
Vl16 1 0 10.0.16.2/24 1 DR 0/0
Vl13 1 0 10.0.13.2/24 1 DR 0/0
Vl38 1 0 10.0.38.2/24 1 DR 0/0
Vl33 1 0 10.0.33.2/24 1 DR 0/0
Vl48 1 0 10.0.48.2/24 1 DR 0/0
Vl43 1 0 10.0.43.2/24 1 DR 0/0
Vl53 1 0 10.0.53.2/24 1 DR 0/0
Vl59 1 0 10.0.59.2/24 1 DR 0/0
Vl58 1 0 10.0.58.2/24 1 DR 0/0
Vl56 1 0 10.0.56.2/24 1 DR 0/0
Lo0 1 0 1.1.1.1/32 100 LOOP 0/0
Vl200 1 0 10.0.200.2/24 1 DR 0/0
Vl199 1 0 10.0.99.254/24 1 DR 0/0
Vl150 1 0 10.0.150.2/24 1 DR 0/0
Vl70 1 0 10.0.70.254/24 1 DR 0/0
Vl60 1 0 10.0.60.254/24 1 DR 0/0
Vl34 1 0 10.0.34.2/24 1 DR 0/0
Vl32 1 0 10.0.32.2/24 1 DR 0/0
Vl28 1 0 10.0.28.2/22 1 DR 0/0
Vl27 1 0 10.0.27.254/24 1 DR 0/0
Vl24 1 0 10.0.24.2/23 1 DR 0/0
Vl23 1 0 10.0.23.2/24 1 DR 0/0
Vl22 1 0 10.0.22.2/24 1 DR 0/0
Vl21 1 0 10.0.21.2/24 1 DR 0/0
Vl20 1 0 10.0.20.2/24 1 DR 0/0
Vl2 1 0 10.1.254.2/16 1 DROTH 2/4
Both are set to DR on the same LAN so they haven't seen each other.
Can you change the
to
Can you connect the 3660 directly to the Cat6k Edge ?
OSPF relies on multicast, are you doing any multicast filtering ?
Purple
What is the function of the 2924 , seems starnge haveing it in the middle of a core dist link . Maybe you can post a "show ip ospf interface" for each side of the link .
193
