OSPF Area
I am having problem in configuring the OSPF. I have four Routers as shown in the diagram.
Duff is adversting the route learned from Area 0 into the Area 1 where it is connected with
Blathers.
Blathers and Duff one interface is in Area 1 and one interface is in Area 0 where they
connecting with Buble and Grwing.
Attached is the configuration of Router
Blathers#show ip os int brief
Interface    PID  Area            IP Address/Mask    Cost  State Nbrs F/C
Fa0          10    0              192.168.3.2/24    1    BDR  1/1
Vl1          10    1              192.168.4.1/24    1    DR    1/1
router ospf 10
log-adjacency-changes
network 192.168.3.0 0.0.0.255 area 0
network 192.168.4.0 0.0.0.255 area 1
Blathers#show ip os database router 192.168.4.2
            OSPF Router with ID (192.168.4.1) (Process ID 10)
Blathers#show ip os database router 192.168.3.1
                Router Link States (Area 0)
  LS age: 43
  Options: (No TOS-capability, DC)
  LS Type: Router Links
  Link State ID: 192.168.3.1
  Advertising Router: 192.168.3.1
  LS Seq Number: 80000026
  Checksum: 0xE59E
  Length: 48
  Number of Links: 2
    Link connected to: a Stub Network
    (Link ID) Network/subnet number: 172.16.6.0
    (Link Data) Network Mask: 255.255.255.0
      Number of TOS metrics: 0
      TOS 0 Metrics: 1
    Link connected to: a Transit Network
    (Link ID) Designated Router address: 192.168.3.1
    (Link Data) Router Interface address: 192.168.3.1
      TOS 0 Metrics: 1
Blathers#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
      D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
      N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
      E1 - OSPF external type 1, E2 - OSPF external type 2
      i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
      ia - IS-IS inter area, * - candidate default, U - per-user static route
      o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C    192.168.4.0/24 is directly connected, Vlan1
C    192.168.3.0/24 is directly connected, FastEthernet0
Duff# show ip os int brief
Fa0/0        10    0              192.168.5.2/24    1    DR    1/1
Fa0/1        10    1              192.168.4.2/24    1    BDR  1/1
uff#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
      o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
      + - replicated route, % - next hop override
      192.168.4.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.4.0/24 is directly connected, FastEthernet0/1
L        192.168.4.2/32 is directly connected, FastEthernet0/1
      192.168.5.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.5.0/24 is directly connected, FastEthernet0/0
L        192.168.5.2/32 is directly connected, FastEthernet0/0
Duff#
Duff#show run | b r o
router ospf 10
network 192.168.5.0 0.0.0.255 area 0
Duff#show ip os database router 192.168.5.1
            OSPF Router with ID (192.168.5.2) (Process ID 10)
Duff#show ip os database router 192.168.5.2
  LS age: 1353
  Link State ID: 192.168.5.2
  Advertising Router: 192.168.5.2
  LS Seq Number: 80000006
  Checksum: 0x665
  Length: 36
  Area Border Router
  Number of Links: 1
    (Link ID) Designated Router address: 192.168.5.2
    (Link Data) Router Interface address: 192.168.5.2
      Number of MTID metrics: 0
      TOS 0 Metrics: 1
                Router Link States (Area 1)
  LS age: 1353
  Checksum: 0xE588
  Length: 36
  Area Border Router
  Number of Links: 1
    (Link ID) Designated Router address: 192.168.4.1
    (Link Data) Router Interface address: 192.168.4.2
      TOS 0 Metrics: 1
Duff#
uff#show ip route
Bumble#show ip os int brief
Fa0/0.200    10    0              192.168.3.1/24    1    DR    1/1
Bumble#show ip os da
Bumble#show ip os database rou
Bumble#show ip route
      192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.2.0/24 is directly connected, FastEthernet0/1
L        192.168.2.1/32 is directly connected, FastEthernet0/1
      192.168.3.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.3.0/24 is directly connected, FastEthernet0/0.200
L        192.168.3.1/32 is directly connected, FastEthernet0/0.200
O IA  192.168.4.0/24 [110/2] via 192.168.3.2, 02:39:11, FastEthernet0/0.200
Bumble#show run | b r o
router ospf 10
Bumble#show ip os database router 192.168.3.1
            OSPF Router with ID (192.168.3.1) (Process ID 10)
  LS age: 661
  LS Seq Number: 80000027
  Checksum: 0xB0A6
  Length: 36
  Number of Links: 1
      TOS 0 Metrics: 1
Bumble#show ip os ne
Neighbor ID    Pri  State          Dead Time  Address        Interface
192.168.4.1      1  FULL/BDR        00:00:39    192.168.3.2    FastEthernet0/0.200
Griwing#show ip os int brief
Fa0/0.101    10    0              192.168.5.1/24    1    BDR  1/1
Griwing#show ip route
O IA 192.168.4.0/24 [110/2] via 192.168.5.2, 00:13:19, FastEthernet0/0.101
C    192.168.5.0/24 is directly connected, FastEthernet0/0.101
C    192.168.6.0/24 is directly connected, FastEthernet0/0.102
Griwing#show ip os ne
192.168.5.2      1  FULL/DR        00:00:34    192.168.5.2    FastEthernet0/0.101
Griwing#show ip os database router 192.168.5.1
            OSPF Router with ID (192.168.6.1) (Process ID 10)
Griwing#show ip os database router 192.168.5.2
  Routing Bit Set on this LSA
  LS age: 1632
  Checksum: 0x665
  Length: 36
  Area Border Router
  Number of Links: 1
      TOS 0 Metrics: 1
Griwing#
O IA 192.168.4.0/24 [110/2] via 192.168.5.2, 00:14:29, FastEthernet0/0.101
Why I am not able to get the routes in Duff and Blatehrs. I am suspecting the virtual link problem.
but My both the routers are having one interface in Area 0 and one interface in Area 1
Then why i m not able to see the routes from the backbone.
Please assist me
OSPF Area
Could you do a sho ip ospf neig on the routers?
We have to establish what neighbors each of the routers see?
Also could you explain how these routers are connected to each other?
OSPF Area
below is the output
Duff>en
Duff#show ip os ne
192.168.6.1       1   FULL/BDR        00:00:33    192.168.5.1     FastEthernet0/0
192.168.4.1       1   FULL/DR         00:00:36    192.168.4.1     FastEthernet0/1
Duff#
192.168.5.2       1   FULL/DR         00:00:39    192.168.5.2     FastEthernet0/0.101
Griwing#
Blathers#show ip os ne
192.168.3.1       1   FULL/BDR        00:00:36    192.168.3.1     FastEthernet0
192.168.5.2       1   FULL/BDR        00:00:34    192.168.4.2     Vlan1
192.168.4.1       1   FULL/DR         00:00:31    192.168.3.2     FastEthernet0/0.200
Bumble#
ALl the routers are connected through Ethernet using one Switch.
Re: OSPF Area
I think I am missing some information here to help.
Could you make out a diagram of some sort because as it stands I do not see connections between your routers. They have different designated routers and appear not to see the other supposed neighbors.
By the way on the switch are do you have OSPF running?
OSPF Area
THis is lab setup and all the routers are connected through a Layer 2 switch.
Balthers-------------------------Area 1---------------------------------------DUFF------------Area 0------------------------GRWING
Area 0
Bumble
Balthers is connected with Bumble (area 0)
DUFF is connected with GRwing   (Area 0)
Both Duff and Balthers are connected with each other through Ethernet in Area 1
No direct communication between Bumble and Grwing.
Re: OSPF Area
(DUFF)----------------------------------(Griwing)
(Blathers)-----------------------------(Bumble)
Is this the way you are currently connectioned?
Looking at it you should have the connection between Duff and Blathers in Area 0 and then Duff and Griwing is Area 1, Blathers and Bumble in Area 1.
The way it is right now you have to build a virtual link between the Area 0's for the routes to be seen in the other Area 0.
273
