OSPF BFD Query
Steev112
i have one query regarding to configure OSPF BFD feaure for only one interface the scenario is,
i have three routers, i just want to configure the BFD on the interface between R2 and R1 as showing below:
R1 ---------- R2 ---------- R3
my question is can i only enable this feaure on R2 interface and R1  not for exampe:
Configuration for R2
!interface Fast Ethernet 0/1
ip address 172.16.10.1 255.255.255.0
bfd interval 50 min_rx 50 multiplier 3
interface Fast Ethernet 3/0.1
ip address 172.17.0.1 255.255.255.0
router ospf 123
log-adjacency-changes detail
network 172.16.0.0 0.0.0.255 area 0
network 172.17.0.0 0.0.0.255 area 0
bfd all-interfaces
Configuration for R1
interface Fast Ethernet 6/0
ip address 172.16.10.2 255.255.255.0
interface Fast Ethernet 6/1
ip address 172.18.0.1 255.255.255.0
router ospf 123
network 172.16.0.0 0.0.255.255 area 0
network 172.18.0.0 0.0.255.255 area 0
as showed in the above example on R1 not configured BFD.
it will work or i must enable both
Which IOS you are running. Please go through below CCO document for configuration help enabling BFD for OSPF on 4500E
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/15-1/XE_330SG/configuration/guide/config/bfd.html#wp1056004
snippet
Note Support on the Catalyst 4500E is limited. Starting with Cisco IOS Release IOS 15.1(1)SG, Bidirectional Forwarding Detection (BFD) is supported only on Catalyst 4900M, and Catalyst 4948E Ethernet switches.
--Pls dont forget to rate helpful posts--
Akash
7 Replies 7
Reza Sharifi
What devices are you using and what version of software?
Hello ,
as understood i must enabled between the two neighbors,  if only one interface enabled BFD the ospf neighbor will not come up.correct me ?
Hello All,
i have 4500x and under ospf i didn't  able to add
router ospf 123
bfd interface fastethernet6/0
can i enable it only under the interface as follow:
interface f6/0
ip ospf bfd
and I should enable the same BFD value on both neighbors. if there is any document mentioned this please share it.
snippet
Akash
Thanks Akash for your support.
Akash Agrawal
I guess it should be running on all participating routers. When we configure BFD below command
"bfd interval 50 min_rx 50 multiplier 3", it says that router will send BFD packet every 50ms and would expect BFD packet every 50ms (min_rx). If does not receive BFD for 3 consecutive time, it will announce neighbor as down. So for other router to send BFD hello, it is required to configure BFD there.
Akash
danrya
Change bfd all-interface under OSPF to the interface you want to run BFD on.
On router 2, change this:
router ospf 123
 bfd all-interfaces
To this:
router ospf 123
 bfd interface fastethernet0/1
and add this to R1:
router ospf 123
That should do it.
