Webcast-Catalyst9k
OSPF/EIGRP ISP redundacny
Two ISP connected multiple spokes with hub
Want 1 ISP to be primary othe to be secondary how can i do it using EIGRP and
OSPF provid me detail
thanks in advance
1 REPLY
Re: OSPF/EIGRP ISP redundacny
If those ISP's are connected to your domain on any router and connected on the routers in your domain running eigrp or ospf. assuming that you can have two default routes on two different routers pointing towards your ISP 1 and ISP2 with different Administrative distance and than redistribute in your OSPF or EIGRP routing protocol.
e.g.
R1 (assumed to be primary router to ISP1)
ip route 0.0.0.0 0.0.0.0 next-hop of ISP 200
redistribute static
R2 (secondary)
ip route 0.0.0.0 0.0.0.0 next-hop ISP2 210
redistribute static in OSPF or EIGRP
135
