OSPF equal cost path
fabio.marino
Hi all,
I have
The network 192.168.0.0 is directly connected to Router A and B. Router A and B are redistributing the network in the ospf area 0.
Router A,B,C,D belong to the same OSPF Area.
Router C is DR. The cost of the link is indicated in the draw.
Question:
Router D (and router C) is using as next hop the Router A for reaching the network 192.168.0.0.
Why the router D is not using the router B as next hop due to the fact that all the possible paths are equal cost?
Thanks.
Fabio,
if the Forwarding Address is not 0.0.0.0, the next hop will be calculated by evaluating the OSPF internal path to the FA.
Useful link: The Effects of the Forwarding Address on Type 5 LSA Path Selection
Otherwise you'll have to look for the components of the costs: Cost to ASBR + Seed cost (E2; default: 20) or external cost (E1).
Rolf
11 Replies 11
Jon Marshall
Fabio
Are C and D not seeing equal cost paths ?
Jon
Every interface of every router inside the mentioned ospf process is seeing the cost ,emtioned in the draw (1)
Fabio
So do C and D have two equal cost paths in the IP routing table to that network ?
Jon
Hi Jon,
no. Router B and C have only one entry in the routing table and both are using as next hop router A.
Fabio,
Jon,
I hope you allow me to join.
Could you please post the output of
- show ip ospf border-routers
- show ip ospf database external 192.168.0.0
from Router D?
Points to focus on:
- metric-type E1/E2
- seed-metric (E2) / external metric (E1)
- costs to ASBRs A and B
- non-zero Forwarding Addresses in Type-5 LSAs
Rolf
daniel.dib
Level 7
Level 7
Can you paste the output of show ip protocols and show ip ospf database router x.x.x.x where x.x.x.x is the RID of Router A and B, C and D.
Daniel Dib
CCIE #37149
Please rate helpful posts.
Daniel Dib
CCIE #37149
CCDE #20160011
Hi All,
I got all your point. No output possible.
I will analise th answer of Rolf.
I just need an indication of what can be.
Fabio,
Rolf
Let me check, I am really curiosi to figure out this point and of course I will let you know.
Thanks all.
Cheers,
Fabio.
At the end the information provided by Rolf fit in my case.
Playing with the cost to reach the ASBR and the metric of the external route I was able to figure out why the router A is the50
preferred exit point: during the redistribution router A is modifying the metric value, in this way C and D are using A as
Thanks all!!!
Jon Marshall
Rolf
Always welcome
Jon
