OSPF Ethernet PtMP
sean_kndy
I am trying to get a PtMP network type running along side an existing broadcast network.  I have a collection of routers connected to a VPLS service and all participating in vlan 80, network type broadcast.  This is problematic if a random VC between a pair of routers decides to break within the VPLS, so PtMP would be more appropriate.
The problem is, I am having a heck of a time getting certain routers to form an adjacency and keep it.  The issue appears to be related to the fact that PtMP advertises /32 routes for the IP on the PtMP interface.  This /32 route is then chosen over the connected route and routed out the vlan 80 interface.  I'm not really sure why this is breaking it, as I know hellos/lsas are multicast on the interface, not unicasted to the IP.  But you can see below in debugging that the routers end up hearing OSPF packets on the vlan 80 sub-if that originated from the vlan 69 sub-if, and complains.
Below is config between two ASR1002 routers running 15.2(4)S2.  The neighborships come up on Gi0/0/0.69 then later fail.  This continually happens.  Note that these 2 ASRs are connected directly between a switch and this adjacency is not even trying to formed across the VPLS service.  I am simply trying to get 2 vlans, one broadcast and one ptmp, running between eachother across a switch.   I labbed this up between a couple 2821s and I can't get the same behavior...
There is no MTU mismatch and full size packets work fine:
ip route 10.1.50.15 255.255.255.255 Gi0/0/0.69   // this is for over-riding ospf's /32 and routing over vlan 80 so we can ping across the 69 sub-interface itself
#ping 10.1.50.15 size 5000 df-bit
Sending 5, 5000-byte ICMP Echos to 10.1.50.15, timeout is 2 seconds:
Packet sent with the DF bit set
First ASR:
INT/OSPF config:
interface GigabitEthernet0/0/0.69
 encapsulation dot1Q 69
 ip address 10.1.50.14 255.255.255.0
 ip mtu 5000
 ip ospf network point-to-multipoint
 mpls ip
interface GigabitEthernet0/0/0.80
 encapsulation dot1Q 80
 ip address 10.1.31.7 255.255.255.0
 ip ospf priority 224
 mpls ip
router ospf 100
 router-id x.x.82.240
 passive-interface default
 no passive-interface GigabitEthernet0/0/0.69
 no passive-interface GigabitEthernet0/0/0.80
 no passive-interface GigabitEthernet0/0/1.3201
 network 10.1.6.96 0.0.0.7 area 0
 network 10.1.31.0 0.0.0.255 area 0
 network 10.1.50.0 0.0.0.255 area 0
Jun 27 18:29:58.590: OSPF-100 ADJ   Gi0/0/0.69: Interface going Up
Jun 27 18:29:58.590: OSPF-100 ADJ   Gi0/0/0.69: Interface state change to UP, new ospf state P2MP
Jun 27 18:30:27.825: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.15, area 0.0.0.0 : src not on the same network
Jun 27 18:30:27.825: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.241 seq 0xE37 opt 0x52 flag 0x7 len 32  mtu 5000 state INIT
Jun 27 18:30:27.825: OSPF-100 ADJ   Gi0/0/0.69: 2 Way Communication to x.x.82.241, state 2WAY
Jun 27 18:30:27.825: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.241: Prepare dbase exchange
Jun 27 18:30:27.825: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.241 seq 0xFF3 opt 0x52 flag 0x7 len 32
Jun 27 18:30:27.825: OSPF-100 ADJ   Gi0/0/0.69: NBR Negotiation Done. We are the SLAVE
Jun 27 18:30:27.826: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.241: Summary list built, size 642
Jun 27 18:30:27.826: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.241 seq 0xE37 opt 0x52 flag 0x2 len 1452
Jun 27 18:30:27.829: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.241 seq 0xE38 opt 0x52 flag 0x3 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.829: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.241 seq 0xE38 opt 0x52 flag 0x2 len 1452
Jun 27 18:30:27.831: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.241 seq 0xE39 opt 0x52 flag 0x3 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.832: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.241 seq 0xE39 opt 0x52 flag 0x2 len 1452
Jun 27 18:30:27.833: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.241 seq 0xE3A opt 0x52 flag 0x3 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.834: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.241 seq 0xE3A opt 0x52 flag 0x2 len 1452
Jun 27 18:30:27.835: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.241 seq 0xE3B opt 0x52 flag 0x3 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.836: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.241 seq 0xE3B opt 0x52 flag 0x2 len 1452
Jun 27 18:30:27.838: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.241 seq 0xE3C opt 0x52 flag 0x3 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.838: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.241 seq 0xE3C opt 0x52 flag 0x2 len 1452
Jun 27 18:30:27.840: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.241 seq 0xE3D opt 0x52 flag 0x3 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.840: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.241 seq 0xE3D opt 0x52 flag 0x2 len 1452
Jun 27 18:30:27.842: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.241 seq 0xE3E opt 0x52 flag 0x3 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.842: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.241 seq 0xE3E opt 0x52 flag 0x2 len 1452
Jun 27 18:30:27.844: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.241 seq 0xE3F opt 0x52 flag 0x3 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.844: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.241 seq 0xE3F opt 0x52 flag 0x2 len 1452
Jun 27 18:30:27.846: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.241 seq 0xE40 opt 0x52 flag 0x3 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.846: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.241 seq 0xE40 opt 0x52 flag 0x2 len 92
Jun 27 18:30:27.847: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.241 seq 0xE41 opt 0x52 flag 0x1 len 92  mtu 5000 state EXCHANGE
Jun 27 18:30:27.847: OSPF-100 ADJ   Gi0/0/0.69: Exchange Done with x.x.82.241
Jun 27 18:30:27.847: OSPF-100 ADJ   Gi0/0/0.69: Synchronized with x.x.82.241, state FULL
Jun 27 18:30:27.847: %OSPF-5-ADJCHG: Process 100, Nbr x.x.82.241 on GigabitEthernet0/0/0.69 from LOADING to FULL, Loading Done
Jun 27 18:30:27.848: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.241 seq 0xE41 opt 0x52 flag 0x0 len 32
Jun 27 18:30:28.350: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.15, area 0.0.0.0 : src not on the same network
Jun 27 18:30:33.294: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.15, area 0.0.0.0 : src not on the same network
Jun 27 18:32:26.927: OSPF-100 ADJ   Gi0/0/0.69: Killing nbr x.x.82.241 due to excessive (25) retransmissions
Jun 27 18:32:26.927: OSPF-100 ADJ   Gi0/0/0.69: x.x.82.241 address 10.1.50.15 is dead, state DOWN
Jun 27 18:32:26.927: %OSPF-5-ADJCHG: Process 100, Nbr x.x.82.241 on GigabitEthernet0/0/0.69 from FULL to DOWN, Neighbor Down: Too many retransmissions
Jun 27 18:32:26.927: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.241: Clean-up dbase exchange
Jun 27 18:32:27.328: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.241 10.1.50.15 is currently ignored
Jun 27 18:32:27.607: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.241 10.1.50.15 is currently ignored
Jun 27 18:32:28.433: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.241 10.1.50.15 is currently ignored
Jun 27 18:32:29.365: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.241 10.1.50.15 is currently ignored
Jun 27 18:32:29.685: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.241 10.1.50.15 is currently ignored
Jun 27 18:32:30.368: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.241 10.1.50.15 is currently ignored
Jun 27 18:32:30.939: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.241 10.1.50.15 is currently ignored
Jun 27 18:32:31.004: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.241 10.1.50.15 is currently ignored
Jun 27 18:32:31.069: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.241 10.1.50.15 is currently ignored
Jun 27 18:32:31.135: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.241 10.1.50.15 is currently ignored
Jun 27 18:32:32.033: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.241 10.1.50.15 is currently ignored
Jun 27 18:32:32.389: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.241 10.1.50.15 is currently ignored
Jun 27 18:32:33.176: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.15, area 0.0.0.0 : src not on the same network
Jun 27 18:32:34.073: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.15, area 0.0.0.0 : src not on the same network
Jun 27 18:32:34.207: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.15, area 0.0.0.0 : src not on the same network
Jun 27 18:32:34.944: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.15, area 0.0.0.0 : src not on the same network
Jun 27 18:32:35.503: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.15, area 0.0.0.0 : src not on the same network
Jun 27 18:32:35.724: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.15, area 0.0.0.0 : src not on the same network
Jun 27 18:32:35.787: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.15, area 0.0.0.0 : src not on the same network
Jun 27 18:32:35.909: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.15, area 0.0.0.0 : src not on the same network
Second ASR:
INT/OSPF config:
 ip address 10.1.50.15 255.255.255.0
 ip mtu 5000
 mpls ip
 ip address 10.1.31.42 255.255.255.0
 ip ospf priority 192
 mpls ip
router ospf 100
 router-id x.x.82.241
 redistribute static subnets route-map ospf-static-redist
 no passive-interface GigabitEthernet0/0/1.766
 no passive-interface GigabitEthernet0/0/1.767
 no passive-interface GigabitEthernet0/0/1.768
 no passive-interface GigabitEthernet0/0/1.769
 no passive-interface GigabitEthernet0/0/1.770
 no passive-interface GigabitEthernet0/0/1.3203
 no passive-interface GigabitEthernet0/0/1.3204
 no passive-interface GigabitEthernet0/0/1.3205
 no passive-interface GigabitEthernet0/0/1.3206
 no passive-interface GigabitEthernet0/0/1.3207
 no passive-interface GigabitEthernet0/0/1.3208
 no passive-interface GigabitEthernet0/0/3.60
 no passive-interface GigabitEthernet0/0/3.2600
 network 10.1.0.49 0.0.0.0 area 0
 network 10.1.0.53 0.0.0.0 area 0
 network 10.1.0.60 0.0.0.0 area 0
 network 10.1.0.63 0.0.0.0 area 0
 network 10.1.6.76 0.0.0.3 area 0
 network 10.1.6.104 0.0.0.7 area 0
 network 172.30.33.24 0.0.0.3 area 0
 network 172.30.33.28 0.0.0.3 area 0
 network 172.30.33.156 0.0.0.3 area 0
 network 172.30.33.168 0.0.0.3 area 0
 network 172.30.34.0 0.0.0.3 area 0
 network 172.30.34.4 0.0.0.3 area 0
 network 172.30.34.8 0.0.0.3 area 0
 network 172.30.34.40 0.0.0.3 area 0
 network 172.30.34.44 0.0.0.3 area 0
 network 172.30.34.48 0.0.0.3 area 0
 network 172.30.34.52 0.0.0.3 area 0
Jun 27 18:29:26.085: OSPF-100 ADJ   Gi0/0/0.69: Interface state change to DOWN, new ospf state DOWN
Jun 27 18:29:58.978: OSPF-100 ADJ   Gi0/0/0.69: Route adjust notification: UP/UP
Jun 27 18:29:58.978: OSPF-100 ADJ   Gi0/0/0.69: Interface going Up
Jun 27 18:29:58.979: OSPF-100 ADJ   Gi0/0/0.69: Interface state change to UP, new ospf state P2MP
Jun 27 18:30:27.506: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:27.827: OSPF-100 ADJ   Gi0/0/0.69: 2 Way Communication to x.x.82.240, state 2WAY
Jun 27 18:30:27.827: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.240: Prepare dbase exchange
Jun 27 18:30:27.827: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.240 seq 0xE37 opt 0x52 flag 0x7 len 32
Jun 27 18:30:27.829: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.240 seq 0xFF3 opt 0x52 flag 0x7 len 32  mtu 5000 state EXSTART
Jun 27 18:30:27.829: OSPF-100 ADJ   Gi0/0/0.69: First DBD and we are not SLAVE
Jun 27 18:30:27.830: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.240 seq 0xE37 opt 0x52 flag 0x2 len 1452  mtu 5000 state EXSTART
Jun 27 18:30:27.830: OSPF-100 ADJ   Gi0/0/0.69: NBR Negotiation Done. We are the MASTER
Jun 27 18:30:27.831: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.240: Summary list built, size 642
Jun 27 18:30:27.831: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.240 seq 0xE38 opt 0x52 flag 0x3 len 1452
Jun 27 18:30:27.833: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.240 seq 0xE38 opt 0x52 flag 0x2 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.833: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.240 seq 0xE39 opt 0x52 flag 0x3 len 1452
Jun 27 18:30:27.835: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.240 seq 0xE39 opt 0x52 flag 0x2 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.835: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.240 seq 0xE3A opt 0x52 flag 0x3 len 1452
Jun 27 18:30:27.837: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.240 seq 0xE3A opt 0x52 flag 0x2 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.837: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.240 seq 0xE3B opt 0x52 flag 0x3 len 1452
Jun 27 18:30:27.839: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.240 seq 0xE3B opt 0x52 flag 0x2 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.839: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.240 seq 0xE3C opt 0x52 flag 0x3 len 1452
Jun 27 18:30:27.841: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.240 seq 0xE3C opt 0x52 flag 0x2 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.841: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.240 seq 0xE3D opt 0x52 flag 0x3 len 1452
Jun 27 18:30:27.843: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.240 seq 0xE3D opt 0x52 flag 0x2 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.843: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.240 seq 0xE3E opt 0x52 flag 0x3 len 1452
Jun 27 18:30:27.845: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.240 seq 0xE3E opt 0x52 flag 0x2 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.845: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.240 seq 0xE3F opt 0x52 flag 0x3 len 1452
Jun 27 18:30:27.847: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.240 seq 0xE3F opt 0x52 flag 0x2 len 1452  mtu 5000 state EXCHANGE
Jun 27 18:30:27.847: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.240 seq 0xE40 opt 0x52 flag 0x3 len 1452
Jun 27 18:30:27.849: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.240 seq 0xE40 opt 0x52 flag 0x2 len 92  mtu 5000 state EXCHANGE
Jun 27 18:30:27.849: OSPF-100 ADJ   Gi0/0/0.69: Send DBD to x.x.82.240 seq 0xE41 opt 0x52 flag 0x1 len 92
Jun 27 18:30:27.851: OSPF-100 ADJ   Gi0/0/0.69: Rcv DBD from x.x.82.240 seq 0xE41 opt 0x52 flag 0x0 len 32  mtu 5000 state EXCHANGE
Jun 27 18:30:27.851: OSPF-100 ADJ   Gi0/0/0.69: Exchange Done with x.x.82.240
Jun 27 18:30:27.851: OSPF-100 ADJ   Gi0/0/0.69: Synchronized with x.x.82.240, state FULL
Jun 27 2014 19:30:27.851 dst: %OSPF-5-ADJCHG: Process 100, Nbr x.x.82.240 on GigabitEthernet0/0/0.69 from LOADING to FULL, Loading Done
Jun 27 18:30:27.851: OSPF-100 ADJ   Gi0/0/0.69: Nbr x.x.82.240: Clean-up dbase exchange
Jun 27 18:30:28.353: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:33.051: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:37.229: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:37.607: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:37.815: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:42.185: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:42.316: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:42.640: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:43.738: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:43.801: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:46.907: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:46.946: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:47.199: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:47.229: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:47.264: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:47.560: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:48.342: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:48.737: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:51.594: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:51.680: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:51.993: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:52.127: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:52.186: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:53.172: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
Jun 27 18:30:53.377: OSPF-100 ADJ   Gi0/0/0.80: Rcv pkt from 10.1.50.14, area 0.0.0.0 : src not on the same network
.. this same msg continues ...
Jun 27 18:32:35.911: OSPF-100 ADJ   Gi0/0/0.69: Killing nbr x.x.82.240 due to excessive (25) retransmissions
Jun 27 18:32:35.911: OSPF-100 ADJ   Gi0/0/0.69: x.x.82.240 address 10.1.50.14 is dead, state DOWN
Jun 27 2014 19:32:35.911 dst: %OSPF-5-ADJCHG: Process 100, Nbr x.x.82.240 on GigabitEthernet0/0/0.69 from FULL to DOWN, Neighbor Down: Too many retransmissions
sean_kndy
So I do believe this is a bug in IOS.  I am running IOS-XE in this case, verison 03.07.02.S.  But I've observed this issue on some older GSRs running IOS 12 as well.
Basically, I have a PtMP network along side a broadcast network between two routers.  The PtMP interface should come up and send a multicast OSPF hello to discover any *directly connected* neighbors it has.  After it receives replies, it then should know that the sender is adjacent and begin sending unicast OSPF packets *out the connected interface* and ignore the routing table.  This isn't what it is doing.  It's looking to the routing table and seeing the /32 route being announced via the other broadcast network between the two routers.  So what happens is the OSPF packets end up hitting the wrong interface on the other side and are discarded.
Now if we change the PtMP to PtMP non-broadcast so that I can actually tell IOS what it's directly connected neighbors are -- it still mis-behaves.  It still looks to the routing table and tries to send OSPF packets across the 'broadcast' network-type interface resulting in the adjacent router discarding those packets thus causing an adjacency to *never* form.  As soon as I nail up a static host route to tell IOS that it should use the directly connected interface (ip route 10.1.50.15 255.255.255.255 Gi0/0/0.69) instead, the adjacency immediately forms and stays up.
I replicated this setup in GNS3 and locally with a couple C2821s and I cannot get this same behavior.  It works fine.  So I think this is a bug affecting some versions of IOS and not others.
