OSPF HSRP traffic blackhole
illay
Hello!
I have a problem with access to the hsrp virtual address on the router.
Detailed info:
I have 1  - core router, and 2 - routers witch connected directly to core router.
1 router connected to core router and have ospf point to point session
2 router connected to core router and have ospf point to point session
On 1 router hsrp active interface, on 2nd router hsrp passive interface.
When traffic goes to virtual hsrp ip add from the core network , they goes to the router 2, and traffic is blackholed.
When i shut down hsrp interface (stanby) on router 2 - all work's fine....
Whoo know - how to fix this situation?
Core router - cisco Nexus7000
router 1, router 2 - cisco Nexus7000  (virtual router)
5 Replies 5
Richard Burts
If two routers are connected directly to the core, and especially if they are point to point links, then I wonder how HSRP is running. Can you post the output of show standby?
Rick
Rick
They are have a L2 connectivity between router1 and router2
router 1
Vlan222 - Group 222 (HSRP-V2) (IPv4)
  Local state is Active, priority 110 (Cfged 110), may preempt
    Forwarding threshold(for vPC), lower: 1 upper: 110
  Hellotime 3 sec, holdtime 10 sec
  Next hello sent in 1.291000 sec(s)
  Virtual IP address is 10.4.52.254 (Cfged)
     Secondary Virtual IP address is 10.4.30.254
     Secondary Virtual IP address is 10.4.29.254
  Active router is local
  Standby router is 10.4.52.252 , priority 90 expires in 5.940000 sec(s)
  Authentication MD5, key-string "AxTxBt"
  Virtual mac address is 0000.0c9f.f099 (Default MAC)
  2 state changes, last state change 1y38w
  IP redundancy name is hsrp-Vlan222-222 (default)
  Secondary VIP(s):
                  10.4.30.254
                  10.4.29.254
router 2
  Local state is Standby, priority 90 (Cfged 90), may preempt
    Forwarding threshold(for vPC), lower: 1 upper: 90
  Next hello sent in 0.698000 sec(s)
  Virtual IP address is 10.4.51.254 (Cfged)
  Active router is 10.4.51.253, priority 110 expires in 1.365000 sec(s)
  Standby router is local
  Authentication MD5, key-string "agb0"
  Virtual mac address is 0000.0c9f.f098 (Default MAC)
  4 state changes, last state change 30w5d
Thank you for providing the additional information. It does show that HSRP does appear to be running correctly and that router 1 is the active router for HSRP. So I started thinking about why would the core send traffic to router 2 if router 1 is the active router. If the core were forwarding to the HSRP virtual address then it should have gone to router 1. Then I realize that you are running OSPF between these routers. OSPF forms its adjacency using the interface address not the virtual address. So if the core is forwarding traffic using OSPF learned routes then it would not be using the HSRP virtual address but would use the interface address and that may be why it was sending traffic to router 2.
Rick
Rick
Hmm, looks like real situation.. 8). Is any ideas how to fix this ?
It's strange solution, but it's work. I shutdown backup hsrp interface and clear configuration of it. And after i reconfrigure this interface like new standby interface and  all start work normaly...
Thanks a lot all.
8)
