01-15-2014 01:50 AM - edited 03-07-2019 05:34 PM
Hi Expert,
I am using a CISCO WS-C6503-E box. My CISCO box is currently up with build Version 12.2(33)SXI3.
My task is to test the IP unnumbered feature with CISCO box. I have read somewhere that CISCO WS-C6503-E supports IP unnumbered on vlan routing interfaces.
But I am not able to find a concrete answer, whether IP unnumbered feature is actually supported on the BOX and build version combination I am using or not?
I have to configure OSPF on IP unnumbered interface. Whenever I try to configure a vlan routing interface as IP unnumbered interface, CISCO box displays following ERROR message:
Router(config)#interface vlan 200
Router(config-if)#ip unnumbered loopback 1
Warning: dynamic routing protocols will not work on SVI interfaces with IP unnumbered configured.
I am pasting running-config also here. Your help and answers are highly appreciated.
Router#show version
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXI3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 27-Oct-09 11:11 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
Router uptime is 32 minutes
Uptime for this control processor is 32 minutes
Time since Router switched to active is 31 minutes
System returned to ROM by reload at 08:23:21 UTC Wed Jan 15 2014 (SP by reload)
System image file is "disk0:s72033-advipservicesk9_wan-mz.122-33.SXI3.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco WS-C6503-E (R7000) processor (revision 1.1) with 458720K/65536K bytes of memory.
Processor board ID FOX093404HJ
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
3 Virtual Ethernet interfaces
50 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x2
Router#
Router#
Router#
Router#sh
Router#show run
Router#show running-config
Building configuration...
Current configuration : 4305 bytes
! Last configuration change at 08:55:58 UTC Wed Jan 15 2014
upgrade fpd auto
version 12.2
service timestamps debug uptime
service timestamps log uptime
service counters max age 10
hostname Router
boot-start-marker
boot system disk0:s72033-advipservicesk9_wan-mz.122-33.SXI3.bin
boot-end-marker
no aaa new-model
ip subnet-zero
mls netflow interface
mls cef error action freeze
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
diagnostic bootup level minimal
redundancy
main-cpu
auto-sync running-config
mode sso
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
interface Loopback1
ip address 61.1.1.1 255.255.255.0
interface GigabitEthernet1/1
no ip address
shutdown
interface GigabitEthernet1/2
no ip address
shutdown
interface TenGigabitEthernet2/1
no ip address
interface TenGigabitEthernet2/2
no ip address
interface TenGigabitEthernet2/3
no ip address
interface TenGigabitEthernet2/4
switchport
switchport access vlan 200
switchport mode access
interface GigabitEthernet3/1
no ip address
interface GigabitEthernet3/2
no ip address
interface GigabitEthernet3/3
no ip address
interface GigabitEthernet3/4
no ip address
interface GigabitEthernet3/5
no ip address
shutdown
interface GigabitEthernet3/6
no ip address
shutdown
interface GigabitEthernet3/7
no ip address
shutdown
interface GigabitEthernet3/8
no ip address
shutdown
interface GigabitEthernet3/9
no ip address
shutdown
interface GigabitEthernet3/10
no ip address
shutdown
interface GigabitEthernet3/11
no ip address
shutdown
interface GigabitEthernet3/12
no ip address
shutdown
interface GigabitEthernet3/13
no ip address
shutdown
interface GigabitEthernet3/14
no ip address
shutdown
interface GigabitEthernet3/15
no ip address
shutdown
interface GigabitEthernet3/16
no ip address
shutdown
interface GigabitEthernet3/17
no ip address
shutdown
interface GigabitEthernet3/18
no ip address
shutdown
interface GigabitEthernet3/19
no ip address
shutdown
interface GigabitEthernet3/20
no ip address
shutdown
interface GigabitEthernet3/21
no ip address
shutdown
interface GigabitEthernet3/22
no ip address
shutdown
interface GigabitEthernet3/23
no ip address
shutdown
interface GigabitEthernet3/24
no ip address
shutdown
interface GigabitEthernet3/25
no ip address
shutdown
interface GigabitEthernet3/26
no ip address
shutdown
interface GigabitEthernet3/27
no ip address
shutdown
interface GigabitEthernet3/28
no ip address
shutdown
interface GigabitEthernet3/29
no ip address
shutdown
interface GigabitEthernet3/30
no ip address
shutdown
interface GigabitEthernet3/31
no ip address
shutdown
interface GigabitEthernet3/32
no ip address
shutdown
interface GigabitEthernet3/33
no ip address
shutdown
interface GigabitEthernet3/34
no ip address
shutdown
interface GigabitEthernet3/35
no ip address
shutdown
interface GigabitEthernet3/36
no ip address
shutdown
interface GigabitEthernet3/37
no ip address
shutdown
interface GigabitEthernet3/38
no ip address
shutdown
interface GigabitEthernet3/39
no ip address
shutdown
interface GigabitEthernet3/40
no ip address
shutdown
interface GigabitEthernet3/41
no ip address
shutdown
interface GigabitEthernet3/42
no ip address
shutdown
interface GigabitEthernet3/43
no ip address
shutdown
interface GigabitEthernet3/44
no ip address
shutdown
interface GigabitEthernet3/45
no ip address
shutdown
interface GigabitEthernet3/46
no ip address
shutdown
interface GigabitEthernet3/47
no ip address
shutdown
interface GigabitEthernet3/48
no ip address
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan100
no ip address
shutdown
interface Vlan200
ip unnumbered Loopback1
ip ospf network point-to-point
router ospf 100
router-id 66.66.66.66
log-adjacency-changes
network 61.1.1.0 0.0.0.255 area 0
ip classless
ip route 32.1.1.1 255.255.255.255 Vlan200
no ip http server
no ip http secure-server
control-plane
dial-peer cor custom
line con 0
line vty 0 4
login
line vty 5 15
login
end
Router#
Thanks a lot in advance..
Abhi
Solved! Go to Solution.
01-15-2014 04:37 AM
According to the Feature Navigator (www.cisco.com/go/fn) it should be in 12.2(33)SXI2 and SXI6. You can do your own search and filter on unnumbered. Then choose IP Unnumbered for VLAN-SVI interfaces. Then choose the platform. You will have all supported images there.
Daniel Dib
CCIE #37149
Please rate helpful posts.
01-15-2014 05:16 AM
Hi Abhi,
Release 12.2(18)SXE and later releases supports the ip unnumbered command on Layer 3 VLAN interfaces, but I believe with similar Limitations and Restrictions applying to the Catalyst 4500:
For IP unnumbered interfaces, the following features are not supported:
–Dynamic routing protocols
–HSRP/VRRP
–Static ARP
–Unnumbered interface and Numbered interface in different VRFs
Unfortunately I coudn't find a better source.
Rolf
01-15-2014 04:37 AM
Daniel Dib
CCIE #37149
01-15-2014 05:01 AM
Hi Daniel,
Thanks a lot for your reply.
Actually I could see the build 12.2(33)SXI3 there in the feature navigator but in platform list, I did not find the box I am using i.e.WS-C6503-E.
That's why I was wondering if feature is actually suported on my CISCO box running with build version 12.2(33)SXI3 or not.
I am first time working on a CISCO box.
Your confirmation would be highly appreciated...
Thansk in advance..
Abhi
01-15-2014 05:16 AM
Hi Abhi,
–HSRP/VRRP
–Static ARP
Rolf
01-15-2014 05:42 AM
Hi Rolf,
So can I conclude that OSPF will work on IP unnumbered interface only if underlying interface is a serial port. Otherwise on ethernet ports, OSPF over IP unnumbered interface will not work?
Abhi
01-15-2014 06:48 AM
Oh - now I recall the discussion we've had a couple of weeks ago:
https://supportforums.cisco.com/message/4126967
I apologize for mentioning the support on the 6500 without pointing to the limitations (I just didn't know that there were any).
According to my best knowledge, yes.
Rolf
