07-15-2014 09:58 AM - edited 03-07-2019 08:04 PM
Hello, I am seeing this error on our router. I read that I need to check the MTU, but it doesn't look as if that is wrong. need somebody help with this issue.
Here is some info that may help. notice the bandwidth set on one end of the connections
interface GigabitEthernet1/1
description RT-04 G1/1 to RT-3 g3/6
switchport access vlan 36
switchport mode access
logging event link-status
interface Vlan36
description GLCR04 to 3MCR01
ip address XX.XX0.202 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf authentication null
ip ospf network point-to-point
router ospf 1
router-id XX.XX0.31
log-adjacency-changes
auto-cost reference-bandwidth 10000
area 0 authentication message-digest
redistribute connected metric 100 metric-type 1 subnets route-map connected-to-ospf
redistribute static metric 100 metric-type 1 subnets route-map statics-to-ospf
network XX.XX0.31 0.0.0.0 area 0
network XX.XX0.200 0.0.0.7 area 0
network XX.XX0.216 0.0.0.7 area 0
network XX.XX1.224 0.0.0.7 area 0
network XX.XX1.232 0.0.0.7 area 0
network XX.XX2.40 0.0.0.7 area 0
ip route 0.0.0.0 0.0.0.0 XX.XX15.19 name Recursive_Default
ip route XX.XX2.31 255.255.255.255 XX.XX96.7
ip route XX.XX3.31 255.255.255.255 XX.XX96.7
ip route XX.XX3.64 255.255.255.248 XX.XX96.7
ip route XX.XX103.0 255.255.255.0 XX.XX99.9
ip route XX.2550.40 255.255.255.248 XX.2552.84
ip route XX.25556.0 255.255.248.0 XX.2552.84
route-map statics-to-eigrp permit 10
match ip address 10
route-map connected-to-ospf permit 10
match ip address 20
route-map statics-to-ospf permit 10
match ip address 10
RT-04#sh cdp ne g1/1
Device ID Local Intrfce Holdtme Capability Platform Port ID
-RT-3.mbusa.corpintra.net
Gig 1/1 138 R S I WS-C6509-EGig 3/6
RT-04
interface GigabitEthernet3/6
switchport
interface Vlan36
////// bandwidth 650000 /////
ip address XX.XX0.201 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
router ospf 1
router-id XX.XX0.1
auto-cost reference-bandwidth 100000
redistribute static
passive-interface default
no passive-interface TenGigabitEthernet1/4
no passive-interface TenGigabitEthernet1/6
no passive-interface TenGigabitEthernet2/4
no passive-interface TenGigabitEthernet2/6
no passive-interface GigabitEthernet3/11
no passive-interface Vlan15
no passive-interface Vlan16
no passive-interface Vlan21
no passive-interface Vlan30
no passive-interface Vlan31
no passive-interface Vlan32
no passive-interface Vlan35
no passive-interface Vlan36
no passive-interface Vlan39
no passive-interface Vlan138
network XX.XX0.1 0.0.0.0 area 0
network XX.XX0.32 0.0.0.7 area 0
network XX.XX0.40 0.0.0.7 area 0
07-15-2014 11:18 AM
Hey,
Try configuring 'ip ospf mtu-ignore'
HTH.
RS.
07-15-2014 11:31 AM
I tried but the command doesn't exist.
does the bandwitch cause that issue.
thanks
07-15-2014 11:57 AM
I don't believe that bandwidth command would do this, did you check the L2 path for any drops or inconsistencies.
HTH.
RS.
08-06-2014 10:53 AM
please see my reply above.
thanks
08-07-2014 08:52 AM
Hey,
Well i only see few input errors on interface g3/6:
RT-R01#sh int g3/6
GigabitEthernet3/6 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 001e.4a3e.3055 (bia 001e.4a3e.3055)
17 input errors, 4 CRC, 4 frame, 0 overrun, 0 ignored
Other than that it looks clean, moreover i believe we don't know when these error occurred.
Clear the counters and see if it increments again, then we may say that we have located the issue.
HTH.
RS.
08-20-2014 01:23 PM
thanks you guys for your help, I was able to fix the issue, we replace the fiber and that corrected it. I had the cable tech check the cable and replace it.
08-06-2014 10:51 AM
Sorry for taking too long to response, but I did some searching and pasted what I think is the issue. it maybe the RT04 (distribution router) and RT01 ( core Router) is having issues. please take a look and let me know what you think or suggest to help fix it.
thanks
RT-04
Aug 3 06:33:30: %OSPF-5-ADJCHG: Process 1, Nbr x.x.0.1 on Vlan36 from DOWN to DOWN, Neighbor Down: Ignore timer expired
Aug 3 06:35:42: %OSPF-5-ADJCHG: Process 1, Nbr x.x.0.1 on Vlan36 from EXCHANGE to DOWN, Neighbor Down: Too many retransmissions
Aug 3 06:36:42: %OSPF-5-ADJCHG: Process 1, Nbr x.x.0.1 on Vlan36 from DOWN to DOWN, Neighbor Down: Ignore timer expired
#sh int g1/1
GigabitEthernet1/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 001b.532c.2740 (bia 001b.532c.2740)
Description: RT-04 G1/1 to RT-01 G4/4
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLH
input flow-control is on, output flow-control is off
Last input 00:00:22, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 7035000 bits/sec, 2282 packets/sec
9798340 packets input, 1946446411 bytes, 0 no buffer
Received 9681756 broadcasts (9681741 multicast)
58188 input errors, 58188 CRC, 0 frame, 0 overrun, 0 ignored
25238596441 packets output, 8056486310288 bytes, 0 underruns
0 lost carrier, 0 no carrier
RT-01. Gig 1/1 135 R S I WS-C6509-EGig 3/6
RT-R01#
Aug 3 06:44:20: %OSPF-5-ADJCHG: Process 1, Nbr x.x.0.31 on Vlan36 from LOADING to FULL, Loading Done
Aug 5 09:17:23: %OSPF-5-ADJCHG: Process 1, Nbr x.x.0.31 on Vlan36 from LOADING to FULL, Loading Done
switchport
end
RT-R01#sh int g3/6
Description:
Full-duplex, 1000Mb/s, media type is 1000BaseLH
input flow-control is off, output flow-control is on
Clock mode is auto
Last input never, output never, output hang never
Last clearing of "show interface" counters 49w0d
5 minute input rate 7009000 bits/sec, 2205 packets/sec
14592357827 packets input, 6303707410324 bytes, 0 no buffer
Received 19558790 broadcasts (19558781 multicasts)
2 runts, 0 giants, 0 throttles
0 watchdog, 0 multicast, 0 pause input
5044948 packets output, 1013598761 bytes, 0 underruns
