04-17-2017 08:44 AM - edited 03-08-2019 10:13 AM
OSPF neighbor can't come up on a DMVPN spoke.
It all started with this message. Tun0 interface has always been up and connectivity has been verified.
*Apr 17 15:26:13.312: %OSPF-5-ADJCHG: Process 302, Nbr100.10.0.1 on Tunnel0 from FULL to DOWN, Neighbor Down: Interface down or detached
debug ip ospf packet
*Apr 17 15:38:23.938: OSPF-302 PAK Tu0: Drop packet, OSPF shut down on interface
CE2#show ip ospf int tun0
Tunnel0 is up, line protocol is up
Internet Address 100.10.0.9/24, Area 51, Attached via Interface Enable
Process ID 302, Router 100.10.0.9, Network Type BROADCAST, Cost: 1000
Topology-MTID Cost Disabled Shutdown Topology Name
0 1000 no no Base
Enabled by interface config, including secondary ip addresses
Transmit Delay is 1 sec, State DOWN, Priority 0
No designated router on this network
No backup designated router on this network
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
oob-resync timeout 40
I am unable to find anything about "Drop packet, OSPF shut down on interface". Known bug?
04-17-2017 08:48 AM
Could you please share the config of both routers? Are you redistributing the source and destination into OSPF as well?
04-17-2017 08:53 AM
DMVPN mGRE interface (no destination, source interface does not run OSPF), no redistribution
the ospf interface state is stuck in down
04-17-2017 08:56 AM
Thank you,
Could you please share the config of the tunnels?
04-17-2017 09:37 AM
In a DMVPN phase 1, we need OSPF point-to-multipoint.
04-17-2017 11:28 AM
in addition to the other posts, make sure that you do not advertise the tunnel sources into OSPF. Here is a generic sample config:
Hub
interface Tunnel1
description DMVPN Tunnnel Hub
bandwidth 1000
ip address 192.168.0.1 255.255.255.0
no ip redirects
ip mtu 1420
ip nhrp authentication dmvpn
ip nhrp map multicast dynamic
ip nhrp network-id 99
ip nhrp holdtime 300
no ip route-cache
ip ospf network broadcast
no ip mroute-cache
delay 1000
tunnel source FastEthernet0/0
tunnel mode gre multipoint
tunnel key 100000
interface FastEthernet0/0
ip address 10.22.118.1 255.255.0.0
duplex auto
speed auto
router ospf 1
log-adjacency-changes
network 192.168.0.0 0.0.0.255 area 0
Spoke
interface Tunnel1
description DMVPN Tunnel Spoke
bandwidth 1000
ip address 192.168.0.2 255.255.255.0
no ip redirects
ip mtu 1420
ip nhrp map 192.168.0.1 10.22.118.1
ip nhrp map multicast 10.22.118.1
ip nhrp nhs 192.168.0.1
no ip route-cache
no ip mroute-cache
delay 1000
tunnel FastEthernet0/0
tunnel key 100000
router ospf 1
04-24-2017 07:01 AM
So a week later I revisited this issue, and found `shutdown` under the OSPF process. Removing `shutdown` solved the problem.
The error message is somewhat vague. I am surprised nobody has run into this issue before. Not sure why the process was shutdown, I don't think I did it manually.
