12-02-2008 10:16 AM - edited 03-06-2019 02:46 AM
Hello all,
I'm looking to set the reference bandwidth on all my OSPF devices to account for 100gb links by using the router config command
auto-cost reference-bandwidth 100000.
Unfortunately, the ASAs in my network don't appear to support this command. I don't think it will cause them an issue but can anyone offer guidance on how devices that don't support a reference-bandwidth setting (such as the ASA) may interact with devices that do? I have yet to find any relevant info.
Thanks in advance,
Matt
12-02-2008 11:23 AM
You can make good use of "ospf cost xxx" interface configuration command as alternative.
HTH...rate if helpful..
12-02-2008 11:36 AM
Yeah, I know I can set the interface cost with the ASA and I probably will, but I'm looking for info on what a best practice might be. Everything I read says all OSPF routers should have the same reference bandwidth but doesn't explain what may happen if a device doesn't support it.
Thanks for the comment and take care!
