OSPF
Can someone please help. I am seeing that on all my switches the ospf route change the time is 03:53:12. Why this change? is this normal?
O 142.101.0.188/30 [110/4] via 142.101.0.74, 03:53:12, GigabitEthernet2/5
[110/4] via 142.101.0.186, 03:53:12, GigabitEthernet2/8
O 142.101.176.0/24 [110/103] via 142.101.0.1, 03:53:12, GigabitEthernet5/1
O 142.101.0.176/30 [110/5] via 142.101.0.17, 03:53:12, POS1/0/0
O 142.101.0.180/30 [110/8] via 142.101.0.74, 03:53:12, GigabitEthernet3/13
[110/8] via 142.101.0.17, 03:53:12, POS1/0/0
Thanks.
Chris
Re: OSPF
Chris,
You can run the following command to find out more about what triggered SPF execution.
show ip ospf statistics detail
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Re: OSPF
Hi hritter,
this is the output for show ip ospf statistics detail. This shows me that there's change at 09:42. Is this because there changes on the two router?
SPF 909 executed 09:42:17 ago, SPF type Full
SPF calculation time (in msec):
SPT Intra D-Intr Summ D-Summ Ext7 D-Ext7 Total
0 0 0 0 0 0 0 0
LSIDs processed R:33 N:6 Stub:183 SN:3 SA:0 X7:0
Change record R,
LSIDs changed 4
Last 10 LSIDs:
142.101.5.2(R) 142.101.5.5(R) 142.101.5.2(R) 142.101.5.5(R)
Summary OSPF SPF statistic
Delta T Intra D-Intra Summ D-Summ Ext D-Ext Total Reason
6d00h 0 0 0 0 0 0 0 R,
5d05h 0 0 0 0 0 0 0 R,
5d04h 0 0 0 0 0 0 0 R,
09:42:27 0 0 4 0 0 0 4 R,
09:42:17 0 0 0 0 0 0 0 R,
Re: OSPF
Chris,
The SPF was indeed triggered by a change in the router LSA for these two routers. Most probably the adjacency status changed on a link between the two routers.
A show log will probably tell you more.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Hall of Fame Super Bronze
Re: OSPF
Re: OSPF
Edison,
The LSA refresh doesn't trigger the SPF if nothing has changed in that LSA.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Re: OSPF
Harold
Stand corrected.
131
