OSPFV3 REdis
HI
Subject OSPFv3
int e0/1 must be seen as external on onother ospf neigh
i have done;
ipv6 ospf 1
redistribute connected route-map O3
route-map O3 permit 10
match interface e0/1
but the interface doesn't appear as ospf external on the neigh is still normal O
HOW CAN SOLVE THIS PROBLEM
Hall of Fame Super Bronze
Re: OSPFV3 REdis
Did you enable OSPF on that interface?
Can you post the entire config?
Enabling OSPF on the interface will override any redistribution.
__
Edison.
Re: OSPFV3 REdis
Dear Edisson i learned from you the Technology.sure no am not enabled the ipv6 ospf 1 area 0 on the Interface E0/1
Re: OSPFV3 REdis
Can you post the config so I can tell you if you have it enabled or not ?
Also, are you seeing the 'O' route on the remote connection as IPv6 OSPF route or IPv4 OSPF route?
Can we see the portion of the routing table you are talking about?
__
Edison.
Re: OSPFV3 REdis
Hi Edisson
Neig router output
O 100.100.30.0/24 [110/74] via 100.100.36.3, 00:52:45, Serial1/0
O 100.100.31.0/24 [110/74] via 100.100.36.3, 00:52:45, Serial1/0
the interface Matching in route-map via redis::
interface Ethernet0/1
ip address 100.100.31.3 255.255.255.0
ipv6 address 2001:233:ABC:31::/64 eui-64
end
Re: OSPFV3 REdis
Ali,
Those are IPv4 OSPF routes. If you want them shown as external on the remote routers, you need to redistribute E0/1 under the OSPF IPv4 routing process, not under the OSPF IPv6 routing process.
Can we see the portion of the OSPF IPv4 routing process from the routing holding the IP 100.100.31.3 ? I bet it has that network included. You need to remove the network and then do a redistribute on that interface.
I'm not sure what's the end goal with this configuration, though.
Re: OSPFV3 REdis
HI EDISSON!
I Do much appreciated ur time to help me out.
this work Book questions
Have a look:
enable ospfv3 on R1 R2 ON ALL interfaces/but e0/1 on R2 must be seen as external network on onether OSPFv3 Neighbor
Re: OSPFV3 REdis
But you are looking at the IPv4 routing table.
First verify you are neighbor with the remote routers.
show ipv6 ospf neighbor
Then, check the ipv6 routing table
show ipv6 route
Stop thinking in IPv4 :) You get to learn all new commands with IPv6.
Re: OSPFV3 REdis
Edisson My Freind
I Got the Problems and i solved too:the Problem was i forgat to add the Command:
ipv6 ospf network point-to-point under the int s1/0
much 10xs
176
