04-24-2008 03:39 AM - edited 03-05-2019 10:34 PM
Hi all, if I want to connect to my routers with an isdn line for out of band management, what do I need to do? would it be a direct connection to the router, and how can you initialize this from my pc using hyperterm or dial up connection
please help
04-25-2008 02:56 AM
You need to use a isdn line from your pc to dial in onto the isdn line connected in the router.
you need to do the config in such a way that it accepts your dial out from the pc with CHAP.
the config in the router will be same/similar to the config you do to accept dial outs from any other router if you are connecting the isdn line onto the bri port.
regds
04-25-2008 03:29 AM
what would I use on my pc to connect to this?
what would the config on the router look like? would I need to use ip addresses and routes ?
