Webcast-Catalyst9k
Out-of-band management interface on 4500X
Each of the 4500X switches in our stack has a Fa1 interface next to the serial console port.  My understanding is that this is to be used for out-of-band management of the switch.  Here's the configuration of the interface:
interface FastEthernet1
vrf forwarding mgmtVrf
ip address 172.21.2.30 255.255.255.0
speed auto
duplex auto
end
The vrf configuration was default.  The only thing I changed was the ip address information.  My question relates to things like domain-lookup and TACACS.  I cannot seem to use this interface for those functions.  Even if I add the following global configuration to my switch:
ip domain-lookup source-interface Fa1
ip tacacs-server source-interface Fa1
the switch is unable to communicate with either the DNS servers reference by the ip name-server command or the TACACS+ servers reference in the tacacs server profile section.
In the case of TACACS, the following debug output is produced when I attempt to login using TACACS:
*Aug 29 10:24:58.874: TPLUS: Queuing AAA Authentication request 38 for processing
*Aug 29 10:24:58.874: TPLUS: processing authentication start request id 38
*Aug 29 10:24:58.874: TPLUS: Authentication start packet created for 38(sdavidso)
*Aug 29 10:24:58.874: TPLUS: Using server 172.19.40.31
*Aug 29 10:24:58.874: TPLUS(00000026)/0: Connect Error No route to host
*Aug 29 10:24:58.874: TPLUS: Choosing next server 172.19.40.32
*Aug 29 10:25:05.539: TPLUS: Queuing AAA Authentication request 38 for processing
*Aug 29 10:25:05.539: TPLUS: processing authentication start request id 38
*Aug 29 10:25:05.539: TPLUS: Authentication start packet created for 38(sdavidso)
*Aug 29 10:25:05.539: TPLUS: Using server 172.19.40.31
*Aug 29 10:25:05.539: TPLUS(00000026)/0: Connect Error No route to host
*Aug 29 10:25:05.539: TPLUS: Choosing next server 172.19.40.32
This output shows that I can ping the TACACS servers:
HQ-4500X-SW1#ping vrf mgmtVrf 172.19.40.31
Sending 5, 100-byte ICMP Echos to 172.19.40.31, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
HQ-4500X-SW1#ping vrf mgmtVrf 172.19.40.32
Sending 5, 100-byte ICMP Echos to 172.19.40.32, timeout is 2 seconds:
Is it deliberate that the Fa1 interface cannot be used for these types of functions or is there something I can do to my configuration to make this work?
Steven
Everyone's tags (6)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Since you can reach the remote TACACS server I assume you created a default route for the mgmtVrf:
     ip route 0.0.0.0 0.0.0.0. vrf mgmtVrf
The other bit you may need to address is in config-sg-tacacs mode:
     ip vrf forwarding mgmtVrf
Marvin,
Thanks for the response.  I have the following route statement in my configuration which enables the device to communicate across L3:
ip route vrf mgmtVrf 0.0.0.0 0.0.0.0 172.21.2.1
I'm not sure what you mean by config-sg-tacacs.  Is that supposed to be a global command in configuration mode or EXEC mode?  I cannot locate anything like that at the CLI.
Steven
Sorry that was unclear.
When are are configuring the "aaa group server tacacs+", your prompt should change to indicate you are in the "config-sg-tacacs" (abbreviation for "configuration security group tacacs+") mode.
Re: Out-of-band management interface on 4500X
No worries.  It's not that you were unclear.  It's that I've been so incredibly lazy that I haven't stopped using the commands that Cisco says will be "deprecated soon".  Now here's my current configuration (as it relates to aaa authentication):
aaa new-model
aaa group server tacacs+ DEED
  ip tacacs source-interface FastEthernet1
aaa authentication login DEED group tacacs+ enable group tacacs+ local
aaa authentication enable default group tacacs+ enable
tacacs server fnb-acs-pri
  address ipv4 172.19.40.31
  key 7
tacacs server fnb-acs-sec
  address ipv4 172.19.40.32
  key 7
line vty 0 4
  exec-timeout 15 0
  password 7
  login authentication DEED
  length 0
  transport input ssh
This configuration doesn't work.  I still get the " No route to host" debug output.
Marvin,
I finally got this to work.  See below for the complete configuration I used which results in a successful login (and an addition prompt to enter enable mode).  I don't understand the difference between defining the servers under the server group mode vs. defining them with the "tacacs server " method but that seems to be one of the issues I was running up against.  aaa configuration on IOS is as clear as mud to me :-)  Thanks for you help.
aaa new-model
server-private 172.19.40.32 key 7
server-private 172.19.40.31 key 7
aaa authentication login default group DEED local
aaa authentication enable default group DEED
speed auto
duplex auto
end
line vty 0 4
exec-timeout 15 0
password 7
length 0
transport input ssh
Glad it helped, thanks for the rating.
AAA setup isn't so hard but Cisco made it a bit confusing with the new syntax - many folks' templates they've been using for a long time might still work but certain features such as the newer management VRF bits need to have everything in the new model to work properly.
Regards.
9656
