Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Outbound Traffic Load Sharing
I have 2 ISP (1=10Mbps, 2=2Mbps) terminated into 2 routers. Routers are terminated into 2 different sets of firewall & the firewall'are terminated into Core switches.
I want to achive traffic load sharing b/w these 2 ISP's in such a manner that a large part of the traffic goes via ISP1 & rest via ISP2. At any point of time if ISP1 has more latency then partial traffic will go via ISP2. If any of the link goes down, the entire load will he transferred to the other one.
Is this possible????
Super Bronze
Re: Outbound Traffic Load Sharing
It might be if your able to use OER or PfR.
Thanx for your reply..But can u plz provide me with some config script for the same..I am attaching the diagram also.
Super Bronze
If your routers are running BGP, an OER config would look something like:
Border router only:
key chain key1
key 1
key-string somekey
oer border
local Loopback0
master x.x.x.x key-chain key1
Combined border/master router
key chain key1
key 1
key-string somekey
oer master
logging
border x.x.x.x key-chain key1
interface FastEthernet0/0 internal
interface Serial0/0 external
learn
throughput
delay
periodic-interval 0
monitor-period 1
aggregation-type bgp
mode passive
mode route control
mode select-exit best
periodic 180
oer border
local Loopback0
master 10.1.127.251 key-chain key1
More information can be found:
http://www.cisco.com/en/US/docs/ios/oer/command/reference/oer_book.html
http://www.cisco.com/en/US/docs/ios/oer/configuration/guide/oer-trf_rte_ctl.html
129
