Webcast-Catalyst9k
output drops on cat6500 Gigabit interface
We saw continuous output drops on a few of our Gigabit interfaces, and can't figure out what are those output drops are and why it is happening. Anyone knows what is the reason of it and is there any way to stop the drop?
Those interfaces are all connecting to the same type of servers for the same application, so I am wondering it is the server interfaces setting, and not our switches.
Please kindly advise.
Thanks.
Ben
Re: output drops on cat6500 Gigabit interface
Hi Ben,
Could you paste the interface output.
Chao
Vishwa
GigabitEthernet1/1 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0024.4111.2329 (bia 0024.4111.2329)
Description: Server1
MTU 9014 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 55/255, rxload 57/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseT
input flow-control is off, output flow-control is on
Clock mode is auto
Last input never, output 00:00:44, output hang never
Last clearing of "show interface" counters 00:30:47
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 5768
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1 minute input rate 225412000 bits/sec, 19598 packets/sec
1 minute output rate 216025000 bits/sec, 3552 packets/sec
36362554 packets input, 52446340542 bytes, 0 no buffer
Received 29 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
6347453 packets output, 49296069677 bytes, 0 underruns
Bronze
So you are saying that you have the same type of servers sitting off from those ports? How are those servers reporting the statistics from their NIC? Do you see any errors there?
Output drops, in my understanding, happens when you try to send more data out an interface than can be received by the equipment at the other end.
I see that you have a 1 minute output rate of appx. 216 Mbps. Could it be that your servers simply are not able to handle that amount of data? Remember that even though the NIC is running at 1 Gbps you cannot be sure that the internal bus, memory etc. can handle that load.
Thanks for the reply.
I will have to check with the server admin for the server NIC statistics. But in your opinion, it is not that the switch output queue is too small, and the output traffic is too much, that the switch is dropping packets in the output queue becuase of the queue size is set too small?
Thanks!
Ben
981
