01-20-2010 08:45 AM - edited 03-06-2019 09:22 AM
Hi Guys,
I have a fastethernet interface connecting to customer kit and both the connecting interfaces are hard coded to 100/full.
We are seeing output drops in 4 digits in a day on both the interfaces.
The interface is underutilised as its doing close to 15Mbps traffic when it can do 100mbps. Its only 15% utilization so congestion is not an issue in this case.
Could you guys shed some light.
FastEthernet2/32 is up, line protocol is up (connected)
Hardware is C6k 100Mb 802.3, address is 0007.ecc9.8c0a (bia 0007.ecc9.8c0a)
Description: xxx
Internet address is xxx
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 24/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is unsupported
Last input 00:00:43, output 00:00:44, output hang never
Last clearing of "show interface" counters 2d03h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1214
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 41000 bits/sec, 13 packets/sec
5 minute output rate 9451000 bits/sec, 4230 packets/sec
L2 Switched: ucast: 34088 pkt, 3109138 bytes - mcast: 0 pkt, 0 bytes
L3 in Switched: ucast: 1452596 pkt, 812879341 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 663675906 pkt, 183244547955 bytes
1477414 packets input, 840680853 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicast)
0 watchdog, 0 multicast, 0 pause input
663713045 packets output, 195788908561 bytes, 0 underruns
Mohammed
01-20-2010 09:23 AM
You should check for a hardware failure. Have you tried other fasethernet ports, cabling and is the result the same?
Sal
01-21-2010 03:08 AM
Hi Mohammed
There are a very high chance that these output drops are a result of a very short traffic-burst peak. Because the average output rate in this snapshot is over 9M, countered on a 5 minute average.
You can try to lower the average timer to see if the amount of traffic is steady or moving up and down. The lowest timer You can set is 30 seconds.
conf t
int fa2/32
load 30
Also another thing to watch for is if this is a bug/cosmetic error. Sometimes packets count as errors, even if they shouldn't.
I have seen errors that increments exactly one error every minute.
/Mikael
01-21-2010 03:26 AM
Hi Guys,
Description: xxx
Internet address is xxxMTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
0 output buffer failures, 0 output buffers swapped outThanks
Mohammed
Hi Mohammed,
Following observation can bee taken into account based on the above outputs:-
The output drop rate 0.00018 %.
Check out the below things to overcome this issue before doing this just Reset the counters using the 'clear counters' command and try the below mentioned steps.
Minimize periodic broadcast traffic like routing and Service Advertising
Protocol (SAP) updates (if applicable) by using access lists or by other
means.
Turn off fast switching for heavily used protocols. For example, turn off
IP fast switching by using the 'no ip route-cache' interface configuration
command.
Hope that helps out your query !!
If helpful do rate the vlauable post.
Ganesh.H
