Webcast-Catalyst9k
pa-a3-t3 card in 6500
I need to find out if I can insert a pa-a3-t3 card into a 6500, is it hot swappable?? Or do I have to reboot the 6500??
1 REPLY
Silver
Re: pa-a3-t3 card in 6500
Hi Eddie
In order to support that card you first will need to install an Enhanced FlexWAN module.
Although the Enhanced FlexWAN module supports online insertion and removal (OIR), individual port adapters do not. To replace port adapters, you must first remove the or Enhanced FlexWAN module from the chassis, and then install or replace the port adapters as required.
Anyway, there is no need to reboot the 6500
Hope this helps
217
