Webcast-Catalyst9k
packate drop
I am getting following message when I put sh log command, I tried it with Cisco output interpreter, but the solution given by the tool is not solving my problem. Cisco showing somrthing about Ipsec tunnel but this is CAT 3750 switch. And I am not able to troubleshoot the kind of problem is the switch facing. Please help me out if anyone can.
The outputs are given below.
sh log
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
Console logging: level debugging, 110860 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 86 messages logged, xml disabled,
filtering disabled
Logging to: vty1(5)
Buffer logging: level debugging, 110860 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Trap logging: level informational, 287316 message lines logged
Log Buffer (4096 bytes):
6
-Traceback= AFC730 BFC660 BFC904 BFE2FC BFEFCC BFCE20 BFD140 CECABC CECC3C CCA094 C1828C BD9DF0 BEEFA4 BED478 BED5C8 BED88C
110845: *Apr 15 00:10:05.725 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet3/0/19, changed state to down
110846: *Apr 15 00:10:06.732 UTC: %LINK-3-UPDOWN: Interface FastEthernet3/0/19, changed state to down
110847: *Apr 15 00:10:07.000 UTC: %ILPOWER-5-IEEE_DISCONNECT: Interface Fa3/0/19: PD removed
110848: *Apr 15 00:10:21.152 UTC: %IP-3-LOOPPAK: Looping packet detected and dropped -
src=172.x.x.x, dst=172.x.x.x, hl=20, tl=78, prot=17, sport=137, dport=137
in=Vlan10, nexthop=172.x.x.x, out=Vlan10
options=none
-Process= "IP Input", ipl= 0, pid= 156
110849: *Apr 15 00:10:24.256 UTC: %LINK-3-UPDOWN: Interface FastEthernet3/0/19, changed state to up
110850: *Apr 15 00:10:25.262 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet3/0/19, changed state to up
Solution as per Cisco is.....
CSCdt73791
Symptoms A tunnel comes up but fails to pass any IP Security (IPSec) traffic, and the following message is displayed on a router:
03:41:43: %IP-3-LOOPPAK: Looping packet detected and dropped - src=http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cavs/192.147.21.165, dst=157.154.194.85, hl=20, tl=44, prot=6, sport=80, dport=4624 in=FastEthernet0/0, nexthop=157.154.252.30, out=FastEthernet0/0
Conditions This symptom is observed when access lists that match to a crypto map include public Port Address Translation (PAT)/Network Address Translation (NAT) IP addresses.
Note Internal devices cannot access each other via the public address even though you can "source ping" or "source Telnet" from the same router to the peer. This is not a platform-specific issue.
Workaround Do not use public addresses and bypass NAT. For more information, refer to the Cisco document at the following location: http://www.cisco.com/warp/public/707/static.html.
Alternate Workaround Include a different network on your NAT pool. If the IP NAT Pool is not on the same network as one of your interfaces, IPSec traffic will be routed. You may also use a Integrated Services Module (ISM).
Silver
Re: packate drop
The error message "%IP-3-LOOPPAK: Looping packet detected and dropped" is usually generated due to IP helper address mis-configuration in which a vlan that is not supposed to receive DHCP broadcast so it loops back that braodcast packet when it is detected. Check the IP helper mis-configuration and verify its configured only on the receiving vlan(s).
Re: packate drop
GRE tunnels are not supported on the 3750 if that is what you have configured. Can we see your configuration?
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225seb/ol7189.htm#wp539899
247
