Community Member
packet loss within rip and ospf domains
hi all, i have created the attached diagram in a lab and all is working fine, i can ping all networks (all loopbacks from each router) however there is a small quetion i would like some help. when i ping from any router e.g if i ping from R5 ro lo3 on R3 i only get 40% success rate and same if i ping the other way. In fact i hardly get 100% success when pinging across the cloud. any ideas??
Thanks in advance
Hall of Fame Super Bronze
Re: packet loss within rip and ospf domains
Please post a traceroute from R5 to R3 and from R3 to R5.
Also post the show ip route from each router toward the destination IP.
__
Edison.
Community Member
Edison here it is
R5#traceroute 3.3.3.3
Type escape sequence to abort
Tracing the route to 3.3.3.3
1 192.168.4.1 892 msec 180
2 172.16.8.3 156 msec * *
Gateway of last resort is not set
1.0.0.0/30 is subnetted, 1 subnets
R 1.1.1.0 [120/4] via 192.168.4.1, 00:00:21, FastEthernet0/0
2.0.0.0/32 is subnetted, 1 subnets
R 2.2.2.2 [120/4] via 192.168.4.1, 00:00:21, FastEthernet0/0
3.0.0.0/32 is subnetted, 1 subnets
R 3.3.3.3 [120/4] via 192.168.4.1, 00:00:21, FastEthernet0/0
5.0.0.0/24 is subnetted, 1 subnets
C 5.5.5.0 is directly connected, Loopback0
6.0.0.0/24 is subnetted, 1 subnets
C 6.6.6.0 is directly connected, Loopback1
172.16.0.0/16 is variably subnetted, 5 subnets, 3 masks
R 172.16.9.252/30 [120/4] via 192.168.4.1, 00:00:21, FastEthernet0/0
R 172.16.8.0/24 [120/4] via 192.168.4.1, 00:00:21, FastEthernet0/0
R 172.16.10.0/24 [120/4] via 192.168.4.1, 00:00:23, FastEthernet0/0
R 172.16.8.2/32 [120/4] via 192.168.4.1, 00:00:23, FastEthernet0/0
R 172.16.8.3/32 [120/4] via 192.168.4.1, 00:00:24, FastEthernet0/0
7.0.0.0/24 is subnetted, 1 subnets
C 7.7.7.0 is directly connected, Loopback2
192.168.4.0/30 is subnetted, 1 subnets
C 192.168.4.0 is directly connected, FastEthernet0/0
R5#
R3#traceroute 5.5.5.5
Tracing the route to 5.5.5.5
1 172.16.9.253 672 msec 1068 msec 80 msec
2 192.168.4.2 912 msec 2284 msec 2140 msec
R3#
R3#ping 5.5.5.5
Sending 5, 100-byte ICMP Echos to 5.5.5.5, timeout is 2 seconds:
Success rate is 20 percent (1/5), round-trip min/avg/max = 336/336/336 ms
R3#
1.0.0.0/32 is subnetted, 1 subnets
O 1.1.1.1 [110/1563] via 172.16.8.1, 00:41:22, Serial1/0
O 2.2.2.2 [110/3125] via 172.16.8.1, 00:41:22, Serial1/0
3.0.0.0/24 is subnetted, 1 subnets
C 3.3.3.0 is directly connected, Loopback0
O E2 5.5.5.0 [110/20] via 172.16.9.253, 00:40:52, Serial1/1
O E2 6.6.6.0 [110/20] via 172.16.9.253, 00:40:52, Serial1/1
C 172.16.9.252/30 is directly connected, Serial1/1
C 172.16.8.0/24 is directly connected, Serial1/0
O 172.16.8.1/32 [110/1562] via 172.16.8.1, 00:41:31, Serial1/0
C 172.16.10.0/24 is directly connected, FastEthernet0/0
O 172.16.8.2/32 [110/3124] via 172.16.8.1, 00:41:31, Serial1/0
O E2 7.7.7.0 [110/20] via 172.16.9.253, 00:41:01, Serial1/1
O E2 192.168.4.0 [110/20] via 172.16.9.253, 00:41:01, Serial1/1
R3#
The Ethernet segment between R5 and R1 seems to have a high latency.
From R5 to R1 the traceroute reports
892ms is quite high for a LAN connection.
Then from R3 to R5, your first hop via the 128k Serial
a little in the high size, it seems you are facing bursty traffic
but when it reaches the LAN segment.
That's over 2 seconds hence causing the request time out.
I suggest you monitor the traffic on those links for saturation. Do you have any network monitoring tool ?
Edit:
I also noticed you are experiencing assymetrical routing.
The path from R5 to R3 goes via the OSPF Area 0 backbone (Frame-Relay) while from R3 to R5 goes via the Serial 128kbps OSPF Area 1.
You need to troubleshoot the configuration there.
Community Member
Edison thanks for the reply. On the assymetrical routing, what would be the best approach to troubleshoot that config?
You need to determine why a path is chosen over the other path. Plenty of things to list, that's how your troubleshooting skills come into play.
It seems this is a lab and not a production network, huh ?
Community Member
yup it is a lab so although not mission critical, it would be nice to understand the reason behind it.
292
