Webcast-Catalyst9k
PAgP Limitation
Is it true that you can't build a layer 3 etherchannel using PAgp?
Bronze
Re: PAgP Limitation
No that is NOT true.
int 1/1
channel-group 1 mode desirable
int 2/2
int po1
no switchport
ip address x.x.x.x y.y.y.y
is a layer 3 etherchannel and works perfectly.
Only limitation that i know of in Pagp is that you can't build cross-stack etherchannels with Pagp. You can with Lacp and mode on.
Re: PAgP Limitation
thank you. One of the engineer at my work was putting doubts in my mind.
Re: PAgP Limitation
I believe it is also true that you can only use PagP interconnecting Cisco devices? If using other branded hardware in your network you should use LACP. This is what we have in our environment.
Bronze
Re: PAgP Limitation
Yes, Pagp is Cisco propriatery. LACP is non-prop standard.
179
