02-23-2010 05:09 PM - edited 03-06-2019 09:52 AM
I have two site connected with two links with Aironet Bridges 1300 for load balance and fault tolerance.
They are configured as following:
1 pair -> Site A root (192.168.230.2/28) ----- Channel 1 ---- nonroot (192.168.230.3/28) Site B
1 pair -> Site A nonroot (192.168.230.4/28) ---- Channel 6 ---- root (192.168.230.5/28) Site B
The default-gateway is a 65XX (Core - Distribution) with Supervisor 720, using a SVI interface (Vlan 900) with IP address 192.168.230.1/28.
The bridges are connected to a Access Switch WS-C2960-TC-L, where I had a FastEtherchannel (port-channel 2) with interfaces F0/9 and F0/10 with the follow configuration:
Interface range f0/9 - 10
switchport mode access
switchport access vlan 900
spanning-tree portfast
channel-group 2 mode desirable
Interfaces port-channel 2
And the other site had similar configuration.
The port-channel is up and operational but the time to react to conectivity failures are too long, I have a PC doing extended ping to various destinations and the timeout are close to 30 sec. The are to much time for everything type of traffic TCP or UDP. The link will be use for traffic of backup files, may be using NFS over TCP or UDP.
Can everybody help about that?????
I need to use something tool to acelerate this time? I read about UDLD aggresive on some forum?
David Salazar
02-23-2010 06:30 PM
I found the following information on Cisco Website.
The Cisco IOS software automatically removes a Fast Ethernet or Gigabit Ethernet interface from the EtherChannel if the interface goes down, and the software automatically adds the interface to the EtherChannel when the interface is back up.
Example of verification:
West_Cat8540# show pagp 1 internal
Flags: S - Device is sending Slow hello. C - Device is in Consistent state.
A - Device is in Auto mode.
Timers:H - Hello timer is running. Q - Quit timer is running.
S - Switching timer is running. I - Interface timer is running.
Channel group 1
Hello Partner PAgP Learning Group
Port Flags State Timers Interval Count Priority Method Ifindex
Gi3/0/0 SC U6/S7 H 30s 1 128 Any 1
I will probe that tomorrow. But I think that is the option to reduce the time.
Thanks.
David Salazar
02-24-2010 08:43 AM
I tried reducing the keepalive time, but It does not work.
Follow the configuration:
NSR-SW-IDF12-1#sh run int port-channel 2
Building configuration...
Current configuration : 172 bytes
interface Port-channel2
description +++ Enlace Wireless REC - DIT +++
load-interval 30
end
NSR-SW-IDF12-1#
NSR-SW-IDF12-1#sh run int f0/9
Current configuration : 230 bytes
interface FastEthernet0/9
logging event bundle-status
logging event spanning-tree
load-interval 30
keepalive 1
end
NSR-SW-IDF12-1#
NSR-SW-IDF12-1#sh run int f0/10
Current configuration : 231 bytes
interface FastEthernet0/10
load-interval 30
keepalive 1
end
NSR-SW-IDF12-1#sh pagp inter
NSR-SW-IDF12-1#sh pagp internal
A - Device is in Auto mode. d - PAgP is down
Timers: H - Hello timer is running. Q - Quit timer is running.
Channel group 2
Fa0/9 SC U6/S7 H 30s 1 128 Any 5002
Fa0/10 SC U6/S7 H 30s 1 128 Any 5002
NSR-SW-IDF12-1#
NSR-SW-IDF12-1#
As you can see the Hello Timer is 30Sec.
The following web site speak about that:
http://www.ieee802.org/3/trunk_study/april98/finn_042898.pdf
Can be that the timers can not be changed. Can anybody help me about that?
