passing vlan traffic over a VPN
hi there,
I've been asked to setup a branch office with a cisco switched solution that matches the setup in head office.
The idea is that we can extend the voice, video and data vlans out to the branch office.
However I wasn't sure whether you can pass vlan traffic across a VPN? To complicate matters further the VPN will be formed between 2 watchguard firewalls.
Does anyone know if this is possible?
Cheers,
Al
VIP Super Bronze
Al,
I would question why they want to extend existing vlans across WAN.  In most case, that is not necessary.  You just need to have 2 local subnets (one for voice and one for data) terminate the subnets on your branch office router and let the router/firewall route them over your VPN.
Hall of Fame Super Silver
Re: passing vlan traffic over a VPN
Possible - not exactly with what you imply is your setup - possibly it can be spoofed with some (non-trivial) effort.
Recommended - no. As Reza stated, routing is the preferred solution set here. There are lots of designs that would enable the business needs without trying to extend / replicate the VLANs.
This is possible. The vlan traffic would just terminate on a L3 device at each end right? and the subnet would simply be routed across the VPN. So, in short its do-able. The vlan subnets would just become part of the interesting traffic.
Kishore
ok thanks for the advice guys. It is much appreciated.
1198
