Pat is giving me static
I am trying to route mail thru my pix
and do not see any traffic passing thru the pix  am I missing something?
commands Ive added.
access-list inbound extended permit tcp any host 192.168.3.5 eq smtp
static (inside,outside) tcp 70.70.70.70 smtp 192.168.3.5 smtp netmask 255.255.255.255
I thought I read something that I needed to play with the fixup command, but dont know.
as you can tell  the 70 interface is the outside of my pix  and the 3.5 is the mail server.
I also cannot figure out the proper debug commands to watch traffic
Dave
Everyone's tags (3)
2 ACCEPTED SOLUTIONS
Re: Pat is giving me static
Dave-
Your config looks good. Turn your logging to debug~
logging buffered debug
logging enable
then try it. From an outside device you can telnet to 70.70.70.70 on port 25
Then check your logs. You should see the TCP connection being built. If there is a problem it should state that too. Feel free to post the results of the log and we'll see if we can help. Also a
show access-list | i 70.70.70.70
will show hit counts on the ACL. They should be incrementing as you test.
Hope it helps.
Dave,
If this is in fact a PIX, then you should run "clear xlate" and that will force the xlate table to be rebuilt. Other than that, your config looks fine.
HTH,
John
HTH, John *** Please rate all useful posts ***
Dave-
logging enable
Hope it helps.
Dave,
HTH,
John
My pix is running 7.2  the logging commands didnt work or do
I submit them from config T.
Ive tried the clear xlate,  im now waiting for some mail to pass
Im still not seeing any traffic.
Do i need an access group statement or anything else to make this work
When i show access-list  i see no hits.
Dave
here is a copy of my config  to demonstrate my lack of skill,  and what i will call for lack of a better term  configuration creep.
Hall of Fame Super Blue
Dave
I can't read your attachment but based on your comment about access-group have you applied the access-list to the outside interface ie.
access-group inbound in interface outside
Jon
wr t
: Saved
PIX Version 7.2(2)
hostname eastpix
domain-name cisco.com
names
dns-guard
interface Ethernet0
nameif outside
security-level 0
ip address 70.70.70.70 255.255.255.248
interface Ethernet1
nameif inside
security-level 100
ip address 192.168.3.1 255.255.255.0
interface Ethernet2
nameif dmz
security-level 4
ip address 192.168.200.1 255.255.255.0
<--- More --->
boot system flash:/pix722.bin
ftp mode passive
dns server-group DefaultDNS
access-list 100 extended permit ip 192.168.3.0 255.255.255.0 10.1.0.0 255.255.0.0
access-list nonat extended permit ip 192.168.3.0 255.255.255.0 10.1.0.0 255.255.0.0
access-list nonat extended permit ip 192.168.3.0 255.255.255.0 10.28.1.0 255.255.255.0
access-list nonat extended permit ip 192.168.3.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list nonat extended permit ip 192.168.3.0 255.255.255.0 192.168.30.0 255.255.255.0
access-list nonat extended permit ip 192.168.3.0 255.255.255.0 192.168.31.0 255.255.255.0
access-list nonat extended permit ip 192.168.3.0 255.255.255.0 192.168.200.0 255.255.255.0
access-list nonat extended permit ip 192.168.3.0 255.255.255.0 192.168.34.0 255.255.255.0
access-list nonat extended permit ip 192.168.3.0 255.255.255.0 192.168.220.0 255.255.255.0
access-list nonat extended permit ip 192.168.3.0 255.255.255.0 192.168.110.0 255.255.255.0
access-list 101 extended permit ip 192.168.3.0 255.255.255.0 10.28.1.0 255.255.255.0
access-list 102 extended permit ip 192.168.3.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list 103 extended permit ip 192.168.3.0 255.255.255.0 192.168.30.0 255.255.255.0
access-list 104 extended permit ip 192.168.3.0 255.255.255.0 192.168.31.0 255.255.255.0
access-list 107 extended permit ip 192.168.3.0 255.255.255.0 192.168.200.0 255.255.255.0
access-list 108 extended permit ip 192.168.3.0 255.255.255.0 192.168.34.0 255.255.255.0
access-list 111 extended permit ip 192.168.3.0 255.255.255.0 192.168.220.0 255.255.255.0
access-list x extended permit icmp any any
access-list 105 extended permit ip 192.168.3.0 255.255.255.0 192.168.110.0 255.255.255.0
<--- More --->
pager lines 24
logging enable
logging buffered debugging
mtu outside 1500
mtu inside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 70.70.70.71 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
<--- More --->
group-policy vpn3000 internal
group-policy vpn3000 attributes
dns-server value 68.87.71.226
vpn-idle-timeout 30
split-tunnel-policy tunnelspecified
split-tunnel-network-list value 107
default-domain value moido.com
no snmp-server location
no snmp-server contact
snmp-server community public
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set strong esp-des esp-md5-hmac
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 8 set transform-set myset
crypto dynamic-map dynmap 10 set transform-set strong
crypto map canton 10 match address 100
crypto map canton 10 set peer 1.1.1.1
crypto map canton 10 set transform-set strong
crypto map canton 20 match address 104
crypto map canton 20 set peer 2.2.2.2
crypto map canton 20 set transform-set strong
crypto map canton 30 match address 103
crypto map canton 30 set peer 3.3.3.3
crypto map canton 30 set transform-set strong
<--- More --->
crypto map canton 40 match address 101
crypto map canton 40 set peer 4.4.4.4
crypto map canton 40 set transform-set strong
crypto map canton 50 match address 105
crypto map canton 50 set peer 5.5.5.5
crypto map canton 50 set transform-set strong
crypto map canton 80 match address 111
crypto map canton 80 set peer 6.6.6.6
crypto map canton 80 set transform-set strong
crypto map canton 65500 ipsec-isakmp dynamic dynmap
crypto map canton interface outside
crypto map mymap 8 ipsec-isakmp dynamic dynmap
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 8
authentication pre-share
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp policy 65535
encryption des
hash sha
<--- More --->
  group 2
lifetime 86400
tunnel-group DefaultL2LGroup ipsec-attributes
pre-shared-key *
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *
isakmp ikev1-user-authentication (outside) none
tunnel-group 1.1.1.1 type ipsec-l2l
tunnel-group 1.1.1.1 ipsec-attributes
pre-shared-key *
tunnel-group 2.2.2.2 type ipsec-l2l
tunnel-group 3.3.3.3 type ipsec-l2l
tunnel-group 4.4.4.4 type ipsec-l2l
tunnel-group 4.4.4.4 ipsec-attributes
pre-shared-key *
tunnel-group 6.6.6.6 type ipsec-l2l
tunnel-group 7.7.7.7 ipsec-attributes
pre-shared-key *
tunnel-group 8.8.8.8 type ipsec-l2l
tunnel-group 8.8.8.8 ipsec-attributes
pre-shared-key *
tunnel-group 9.9.9.9 type ipsec-l2l
tunnel-group 9.9.9.9 ipsec-attributes
pre-shared-key *
<--- More --->
pre-shared-key *
tunnel-group 2.2.2.2 ipsec-attributes
pre-shared-key *
tunnel-group vpn3000 type ipsec-ra
tunnel-group vpn3000 general-attributes
default-group-policy vpn3000
tunnel-group vpn3000 ipsec-attributes
pre-shared-key *
tunnel-group 0.0.0.0 type ipsec-l2l
tunnel-group 0.0.0.0 ipsec-attributes
pre-shared-key *
tunnel-group 3.3.3.3 ipsec-attributes
pre-shared-key *
pre-shared-key *
tunnel-group 5.5.5.5 type ipsec-l2l
tunnel-group 5.5.5.5 ipsec-attributes
<--- More --->
  pre-shared-key *
isakmp keepalive threshold 10 retry 3
tunnel-group 6.6.6.6 ipsec-attributes
pre-shared-key *
telnet 192.168.3.0 255.255.255.0 inside
telnet 192.168.200.0 255.255.255.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 30
ssh version 1
console timeout 0
management-access inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
<--- More --->
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect http
  inspect ils
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
ssl encryption des-sha1 rc4-md5
prompt hostname context
Cryptochecksum:7ce604f250b00ade16927c4c44d02ff9
: end
[OK]
David,
This line:
needs to be changed to your public address that you're mapping to:
access-list inbound extended permit tcp any host 70.70.70.70 eq smtp
That should get you fixed up....
HTH,
John
472
