PBR 4006 Supervisor III
amunoz
Hi:
I need implement PBR in a switch 4006 with supervisor III, i only found information for the same supervisor III but for switchs 4500, the question is, the comands supported by supervisor III in a 4500 are suported by the same supervisor III in 4006? or, can i implement PBR (route-map in a interface)
in 4006?
thanks in advance.
szahid
Level 3
Level 3
You can implement PBR on sup3. In Cat4000/4500 switches , all the intelligence is in the sup and chassis for the most part has no relevance to what features can or cannot be enabled. You can implement PBR in 4006 using the example you found for 4500.
thanks
Salman.
szahid
Level 3
Level 3
thanks
Salman.
OK thanks a lot
