ā08-25-2010 01:58 AM - edited ā03-06-2019 12:38 PM
Hi all,
question about PBR:
can take precedence on connected route in any way?
I've tried putting ACL restrictive than subnet but it seems not to work.
I need to route traffic from subnet A to B towards a FW, subnet B is configured both on 6K and on FW. so i've putted ip local policy con subnet A but no results
Any idea?
ā08-25-2010 03:48 AM
Hi Das,
No, PBR cannot take precedence when destination is directly connected.
I am thinking of using different vrf for subnet A and subnet B might help on your case.
HTH,
Lei Tian
ā08-25-2010 01:06 PM
Hi Lei,
tnx a lot for answer!
I was thinking about different VRF but i need (sometimes) traffic intra-vlan. So in VRF fashion with Nexus 7000 release 4.2.X (but i'm pretty sure also in 5.X) route leaking with import-export is not possible yet.
maybe i'll split static route for hitting a longest match routing.
I also must say that will be not so bad to have e way to overcome this 'limitation' of connected route.
What's a shame!
tnx a lot.
Dan
ā08-25-2010 03:39 PM
Hi Dan,
Yes, the vrf import/export feature is not there yet. The work around is using pbr to do vrf leaking.
I was thinking using some static routes to leak between vrf and global routing table. Here is my configure;
ip vrf points
int vlan A
ip vrf forwarding points
ip add 10.10.24.1 255.255.255.0
int vlan B
ip add 10.10.23.1 255.255.255.0
ip route vrf points 10.10.23.0 255.255.255.0 FW_IP
*traffic from vlan A to vlan B send to FW*
ip route vrf points 10.10.23.2 255.255.255.255 10.10.23.2 global
*traffic from vlan A to specific IP in vlan B send to global*
ip route 10.10.24.0 255.255.255.0 vlan A
*return traffic from specific IP in vlan B to vlan A*
I am sure your requirement is more complex than this config, and NXOS has different syntax. Just want to throw an idea.
Lei Tian
ā08-26-2010 01:01 AM
hi Lei,
tnx again.
topology is not complex, just all IFC in VRF, nothing in global
have 'u got axample of vrf leaking with PBR?
tnx and have nice day
Dan
ā08-26-2010 03:32 AM
Hi Dan,
feature pbr
vlan 10,20
vrf context vlanA
vrf context vlanB
ip access-list vlanA_to_vlanB
permit ip 10.10.10.0/24 10.10.20.0/24
ip access-list vlanB_to_vlanA
permit 10.10.20.0/24 10.10.10.0/24
route-map vlanA_to_vlanB
match ip address vlanA_to_vlanB
set vrf vlanB
route-map vlanB_to_vlanA
match ip address vlanB_to_vlanA
set vrf vlanA
int vlan10
vrf member vlanA
ip add 10.10.10.1/24
ip policy route-map vlanA_to_vlanB
int vlan20
vrf member vlanB
ip add 10.10.20.1/24
ip policy route-map vlanB_to_vlanA
Lei Tian
ā08-26-2010 04:49 AM
Hi Lei,
tnx was helpful.
do 'u think PBR (in this particular) is done in HW or is SW based?
tnx again and have nice day
ā08-26-2010 06:35 AM
Hi Dan,
I believe it is in hardware, but I was not able to find that in datasheet.
Hope someone can jump in if you have the CCO link.
Lei Tian
