PBR on SVI and Next Hop
I have a layer 3 switch (4506) connected to a WAN router.
The 4506 has several SVI's which are the gateways to different subnets (i.e. 10.208.2.x, 10.208.3.x, 10.208.4.x, etc.).
After creating a route-map, do I apply it to the incoming physical port on that 4506 or do I apply it to the SVI for that subnet?
Second, does my next hop have to be an interface (ip address) on the same 4506 or could it be on the WAN router?
Thanks in advance.
2 ACCEPTED SOLUTIONS
Silver
Re: PBR on SVI and Next Hop
yes. you apply it to the SVI interface.
set ip next-hop {ip-address [...ip-address] }
Syntax Description
ip-address
IP address of the next hop to which packets are output. It must be the address of an adjacent router.
Hall of Fame Super Silver
Hello David,
the ip policy command has to be applied on SVI(s) interfaces
the IP next-hop has to be an IP address of ANOTHER box, the WAN router or other device to which you want to direct traffic
Hope to help
Giuseppe
Silver
Syntax Description
ip-address
Yes you can apply check out the below link hope that helps out your query !!
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.1_19_ea1/configuration/guide/swiprout.html#wp1052491
Ganesh.H
Hello David,
Hope to help
Giuseppe
2045
