Community Member
PBR
hello,
I have a question please, a packet that match acl 101 in a route-map with permit statement but no set command is configured,
will it be routed according to routing table ?
access-list 101 permit ip 10.1.0.0 0.0.255.255 10.0.0.0 0.255.255.255
route-map XYZ permit 101
 match ip address 101
Hi Halil,
Hi Halil,
Yes it is necessary.
Please check the following document:
http://www.cisco.com/c/en/us/td/docs/ios/12_2/qos/configuration/guide/fqos_c/qcfpbr.html
Aditya
Please rate helpful posts.
Community Member
Hello Halil,
Hello Halil,
yes it will route based on routing table with no set command or set command with dummy/non-exist IP address in either case.
but it would punted, it means it would processed by CPU not by PFC.
regards,
82
