pc to router
hi all im learning ccna and have a lab at home,and doin some labs,now i know the connection between pc and router should be crossover cable but thinking i had a crossover i plugged in a straight through cable and the lab worked so when i realised i changed for the xover and the lab still works,is this right do some routers work this out for you???i presume the exam will say just a xover but just wanted too check,the routers a 3640
thanks chris
1 ACCEPTED SOLUTION
Re: pc to router
yes it is normal. almost all ethernet port have auto-mdix therefore no matter which cable you plug in the port will go up.
for more see
http://en.wikipedia.org/wiki/Medium_dependent_interface
regards
Riccardo
Re: pc to router
for more see
regards
Riccardo
pc to router
thank you riccardo
chris
236
