Per Vlan Management IP@
For an L2 switch is it possible to define one IP@ for each vlan used on that switch ?
And best practice is to use one single IP@ for management of an L2 switch or one IP@ per vlan ?
Bronze
Re: Per Vlan Management IP@
A layer 2 switch will typically have one IP address for management.
Hall of Fame Super Silver
a l2 switch can have only one management vlan.
I saw this on C2950 when you define a second SVI the first one is put in shudown.
if you enable the one disabled the second is shutted.
if the device is L3 capable but acts as a L2 switch it could have multiple SVIs but there is no need for this as Etienne noted
Hope to help
Giuseppe
And is it recommended to always use vlan 1 for defining management IP@ ? Or better a separate dedicated vlan, which is not used for any other traffic except for remote connection to the switch?
Bronze
I usually avoid to use VLAN1 and create a specific VLAN for management.
So to define one management IP@ per vlan is not recommended?
Hello Badalam,
use only one different from Vlan 1 and different from vlans where end users connect.
The suggestion is that every campus should have a dedicated management vlan to reach all devices.
This is for telnet/ssh and snmp, syslog and so on.
using vlan1 is not recommended for security reasons.
Having a dedicated management vlan can help keep devices reachable while there are problems on user vlans
Hope to help
Giuseppe
Purple
Vlan1 is also used for control plane traffic such as cdp , vtp etcc so it is better not to run production traffic across vlan 1. It can be any other vlan.
166
