Community Member
performance troubleshooting
using a Cisco 2960 switch I get very poor connection to the network
other switches on the network allow a fast reliable connection.
when I switch a PC from this 2960 to other switches the performance boost immediately
how do I troubleshoot and find the reason? (it is a new out of the box switch so I guess it is a config issue and not hardware related)
Re: performance troubleshooting
I don't know if you have already configured portfast on the access ports. If it isn't can you configure 'spanning-tree portfast' on the ports connected to PCs and see if that helps.
If you are still having issues can you give more details of your problem.
Sundar
Community Member
this is the port config:
interface FastEthernet0/16
description ***
switchport access vlan 201
switchport mode access
speed 100
duplex full
FastEthernet0/16 is down, line protocol is down (notconnect)
Hardware is Fast Ethernet, address is 001b.2aaf.a490 (bia 001b.2aaf.a490)
Description: ***
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 04:16:48, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
23123090 packets input, 3306271391 bytes, 0 no buffer
Received 797083 broadcasts (0 multicast)
3 runts, 0 giants, 0 throttles
70945 input errors, 70654 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 274522 multicast, 0 pause input
1004846643 packets output, 2307488030 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
it is a plain LAn with few VLANs
what other data would help here?
As you can see there is a lot of CRC errors on the port. It can be due to a duplex issue, bad cable, port, NIC etc. As a first step, can you use the following configuration and see if it helps.
description ***
speed auto
duplex auto
Sundar
Community Member
looking at other ports on the same switch, CRC errors show all over the place
all the ports are configed in the same way
It could be duplex mismatch between the switch and PC NICs. If you have the NIC duplex set to auto negotiate I would suggest using the duplex to auto on the switch port and see that indeed is the problem here.
Community Member
adding spanning-tree portfast seem to fix the problem.
is there a way (other then booting the switch) to clear the CRC count on each interface so I can check it for additional errors?
Glad to hear that :)
Clear counters should clear the counters.
Community Member
thanks!
No problem. Also, if the CRC errors come back consider setting the duplex to auto.
182
