Community Member
permitting specified commands only
We have TACACS enabled in our routers. I wanted to restrict user access to only particular commands. I am providing those commands below.
Router#term len 0
Router#sh clock
Router#sh ip int br
Router#sh env all
Router#sh int s0/0
Router#sh int s0/1
Router#ping 10.30.250.137
Router#conf t
Router(config)#int se0/0
Router(config-if)#no backup int br0/0
Router#exit
Router#isdn call int bri 0/0 22861600
Router#sh isdn a
Router#sh isdn status
Router(config-if)#backup int bri0/0
Router#sh int bri0/0
Router#sh run
Nothing more than these commands should be allowed for configuration. Can someone advice me for required configuration in Router as well as cisco ACS.
SKRAO
1 REPLY
Community Member
Re: permitting specified commands only
Hi Siva,
You will have to add these commands in Shared Profile Components-->shell command authorization sets. And then associate this to the user under user setup.
And ofcourse you have to enable command authorization in router pointing to the tacacs server.
Kiran
124
