Physical connection to a 3550 L3 ROUTED port ??
Say I have a 3550, with a ROUTED port, with an IP address of 10.1.1.1
        interface fa 0/10
          no switchport
          ip address 10.1.1.1 255.255.255.0
        I also have a SVI's and VLAN (172) with 5 ports on it (fa 0/27 - 31)
         vlan 172
           name vlan for servers
         Interface vlan 172
                no switchport
                ip address 172.16.15.1 255.255.255.0
         I have a server attached to one of these 5 ports, in access mode with IP 172.16.15.100
           interface fa 0/27
                 switchport access vlan 172
                  description Connect to server with ip 172.16.15.100
Now, I have a PC on a switch in vlan 10 with IP 10.1.1.100 with gw as 10.1.1.1 . Its connected to a 2950
The 2950 (fa 0/1) is connected to the 3550 (fa 0/10 . .routed port ....see config above).
             (Main question relates to how the 2950 switchport should be connected to the routed port).
So we have
       [ PC_A ] <----- access vlan10 ------> [ Sw 2950] < fa0/1------ Cat 5------ fa0/10---> [ 3550]  <- fa0/27-------->Server_B
     PC_A :-
              IP address :  10.1.1.100/24
              Default Gw :  10.1.1.1
              VLAN 10 on SW_2950
     Server_B :-
              IP address : 172.16.15.100
              g/w of 172.16.15.1
              VLAN 172 (access mode) on port fa0/27 of 3550.
So now, the QUESTION is :-
          Assuming that  routing on the 3550 is enabled.
          To get PC_A to talk to Server_B, what does the config on port fa 0/1 on the 2950 have to be ???
          A. Can it just be a Access mode on vlan 10 ? (My best guess)
          B. Can it be a Trunk ?
                       not sure, since 3550 does not allow sub interfaces on routed ports
          C. Other  ?
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: Physical connection to a 3550 L3 ROUTED port ??
Your best guess is correct, fa0/1 on the 2950 should be allocated to vlan 10.
Incidentally, normally with a L3 switch you would not use a routed port, you would simply allocate fa0/10 on the 3550 into vlan 10 and then create a L3 SVI for vlan 10 on the 3550 eg.
int vlan 10
but your way will still work.
Jon
1 REPLY
int vlan 10
Jon
525
