12-01-2007 12:13 PM - edited 03-05-2019 07:45 PM
I have two sources multicasting for the same group. Network connectivity is as follows:
source s1 (on vlan X) and s2 (on vlan Y)------multicast router------Receiver (on vlan Z)
Receiver is using IGMP V2 to join the group. Given the fact that Multicast Router can see both sources for the same group, how is Multicasting router supposed to select which (S,G) channel should be used for forwarding multicast to receiver?
12-01-2007 01:51 PM
It doesn't. If you want to be able to select both your stream and your source, you need to do PIM-SSM and IGMPv3.
With PIM-SM and IGMPv2, the receiver will get both streams.
12-01-2007 02:01 PM
Well, that's interesting. In my case, router is choosing only one stream. For the other stream, "show ip mroute" output indicates Incoming interface as Null. "show ip mroute active" only shows the first (active) stream.
12-01-2007 10:27 PM
Which entry has the iif as null?(s,G) or (*,G).
-Nambi
12-02-2007 11:50 AM
Vlan Z should definitely receive both streams. You can change that by using IGMPv2 for the receiver on vlan Z or use IGMPv2 to v3 mapping on the multicast routing.
