Ping At L3 3560
Dear Sir,
I have layer3 3560 switch, switch Ip 192.168.1.1
I have One Pc with ip 192.168.1.10 & other Pc 192.168.1.11
Some times I can not get the ping of 192.168.1.11 from 192.168.1.10
At that time if ping its gateway means 192,168.1.1 , its gets reply , an then
Started reply from 192.168.1.11.
Why it was occur I can not understand. Help Me.
Thanking You
Dipak Parmar
Silver
Re: Ping At L3 3560
Have you configured default gateway on both pc's.
Satish
Re: Ping At L3 3560
Does the pcs connected to same switch or different,
if in same switch check the port setting (speed& duplex).
have you seek with any other Pc like IP in the same subnet,
if pcs in different switch during the problem time try ping with different Pc, and check in the uplink port any errors.
Re: Ping At L3 3560
they both are on same switch
i checked speed & Duplex
if i check ping for other pc i do not get
reply at that time
thanking you
Re: Ping At L3 3560
Sir ,
ya configured that.
Silver
Re: Ping At L3 3560
Hi Dipak ,
can you paste the config of the switch .....
Satish
Re: Ping At L3 3560
HI Dipak,
Can you please check the "Netmask" configured is same for Switch IP, PC1 & PC2.
Check the Default Gateway of the PC's.
See the Port Status to which PC1 & PC2 connected. Try to do some extended Ping from Switch.
Check whether the ports are in Forwarding / Blocking State.
Do multiple ping from different Src - to - destn.. & see the status of the Switch Int...
PLS Rate if Helps
Best Regards,
Guru Prasad R
Re: Ping At L3 3560
sir,
subnet mask of switch ip Pc1,Pc2 is 255.255.255.0
both pc defalt gateway 192.168.1.1/24
port status up
Re: Ping At L3 3560
Try to see logs (show loggin), see if there are any changes on port status when the problem accures.
Check you arp table on the switch, see if you're able to see both Pc's on arp on the same Vlan. Check you arp table on the Pc's as well. i suspect you have some sort of ARP issue on on of your servers or the switch.
If you'll post the running-config, it might help finding the problem more rapidly.
Tim
Re: Ping At L3 3560
Thanks TIMor,
I have same suspects ,
how I increase my arp cache , & rapid
Refresh rate to sort this arp issue
I am sending my configuration
at Switch
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime localtime
ip subnet-zero
ip routing
no ip domain-lookup
no errdisable detect cause pagp-flap
no errdisable detect cause dtp-flap
no errdisable detect cause link-flap
no errdisable detect cause l2ptguard
no errdisable detect cause sfp-config-mismatch
no errdisable detect cause gbic-invalid
no errdisable detect cause dhcp-rate-limit
no errdisable detect cause arp-inspection
no errdisable detect cause loopback
no file verify auto
spanning-tree mode pvst
spanning-tree logging
no spanning-tree vlan 2,6
vlan internal allocation policy ascending
interface GigabitEthernet0/1
description "PC2"
switchport access vlan 6
switchport mode access
speed 1000
duplex full
interface GigabitEthernet0/2
description "PC1"
speed 1000
duplex full
interface Vlan6
description "Third Floor LAN"
ip classless
Silver
Re: Ping At L3 3560
Hi ,
set the speed and duplex on g0/1 and g0/2 of switch to "auto" and check the issue.
satish
Re: Ping At L3 3560
Hi Dipak,
Are u using 3560 as Layer3 or Layer2. I mean if you have vlans, you can check that the PCs are on same VLAN.
Pls rate if it helps..
Re: Ping At L3 3560
ya Dear they are on same VLAN
Re: Ping At L3 3560
yes
Re: Ping At L3 3560
Try putting the switch ports into a portfast mode and see if you can ping.
198
