ping from inside interface not working
I am using pix7.0 device
ping x.x.x.x is working fine, but if I am trying to ping from inside interface ping fails
vpn-f1# ping outside x.x.x.x
Sending 5, 100-byte ICMP Echos to x.x.x.x, timeout is 2 seconds:
Success rate is 0 percent (0/5)
"outside" is my inside interface.
Would be great if I get any help.
TIA,
Radhika
Re: ping from inside interface not working
What is the security value you have given to your interfaces and what are the interfaces configured on your pix.
Radhika,
Send me your Pix config.
-amit singh
As u have mentioned that outside is u r inside interface i think there is problem with the security level on the interface.
Mahmood
attaching my config
Radhika
After seeing the confiuration, I think the problem is with routing. If you are trying to ping some server in Internet, the it wont, because the default route is towards inside interface not outside interface.
Try to add route outside 0 0 x.x.x.x 1 and then ping.
Suresh Jain
Hi Suresh,
Pix's Inside interface is actually the outside interface. So I think the default route is correct.
To add some information , ping from the devices on inside network is also working.
Seems problem is only when I try to ping from the device.
Radhika
just to clarify - when you try to ping x.x.x.x from the inside network it works but when you try to ping x.x.x.x from the firewall it doesn't work?
yes
can you enable debug icmp on the firewall then do a ping from the firewall then paste it here. that will show us what's happening of the firewall when you do a ping. also can you install a analogx packetmon on the workstation you are trying to ping so it could capture if the workstation is seeing any packets coming in. paste the result here also. if what you're trying to ping is a network equipment just enable icmp debug then paste the result here.
I don't see any debug message even though I enabled it.
xxxx(config)# ping outside x.x.x.x
Radhika
Radhika,
There is no natting being done in your configuration. If you connected your inside interface which you are using as outside to internet then you wont be able to ping.
Suresh Jain
Add a Access list with ICMP Permit any any and implement it in both Insid and Outside interface.
Hope this will help.
Danny
Hey,
Please i didnt checked the configuration you have attached. Without NAT Acl wont work in PIX. Please ignore the previous update.
Danny
Hi Danny/Suresh,
I did no nat as below.
access-list nonat extended permit ip any any
nat (outside) 0 access-list nonat
seems no use.
Radhika
Radhika,
Can you please try by doing NAT.
Suresh Jain
Hi Radhika,
you have permited IP any any, try ICMP any any
Reg,
Dany
Hi Radhika,
Remove the the no nat Access list and nat (Outside) and try the following config#
access-list acl_outside extended permit icmp any any
access-group acl_outside in interface outside
access-group acl_outside in interface inside
nat-cont
nat(inside) 1 0 0
global(out) 1 int
Hope it will solve your problem
Reg
Dany
no use :(
Radhika
what are you trying to achieve?
ping x.x.x.x from y.y.y.y
or
ping x.x.x.x from firewall cli
177
