Webcast-Catalyst9k
ping from PC1 can not reach R1 and PC2.
I don't know why. I'm testing Vlan
principle. Can anyone help me?
R1 : E0 10.43.6.1, E1 10.43.4.1
SW1 : 10.43.6.2 SW2 : 10.43.4.2
PC1 : 10.43.6.5 PC2 : 10.43.4.5
E0 from R1 connects Port1 from SW1
Port2 from SW1 connects PC1
E1 from R1 connects Port1 from SW2
Port2 from SW2 connects PC2
and here is configuration for SW1
SW1#vlan database
SW1#vlan 20 name test
SW1#conf t
SW1#int FE0/1
SW1#switchport access vlan 20
SW1#int FE0/2
SW2#vlan database
SW2#vlan 20 name test
SW2#conf t
SW2#int FE0/1
SW2#switchport access vlan 20
SW2#int FE0/2
1 REPLY
Hall of Fame Super Silver
Re: ping from PC1 can not reach R1 and PC2.
Hello Sangbong,
you have only one router connected to the two switches
verify on PC1 that you have provided the right default gateway
use ipconfig /all it has to be 10.43.6.1
you can check the ARP table with arp -g on the PC
on the router verify that ip routing is enabled
conf t
ip routing
PC2 has to use as DEf GW 10.43.4.1
Hope to help
Giuseppe
205
