Ping in IOS
chee-ben.tan
What is the IOS PING command for a DOS style below?
P:\>ping 10.1.1.1
Pinging 10.1.1.1 with 32 bytes of data:
Reply from 10.1.1.1: bytes=32 time<1ms TTL=253
7 Replies 7
m.sir
Level 7
Level 7
Its no suprise its command
PING 10.1.1.1
Offers some more option (like change source, specify packet lenght, packet numbers etc..)
try ? to see options
PING 10.1.1.1 ?
Well, the optionsdoes the offer Windows style ping. Any ideas?
I mean the Ping 10.1.1.1 ? option does not offer any Windows style Ping.
You will not get the ping as specifed in the windows dos commnad.
You need to use "?"
Ping 10.1.1.1 ?
will provide you with option.
simple example is in win we have ping 10.1.1.1 -t
on cisco it would be
ping 10.1.1.1 rep 100 or 100000
Hope this helps
Well, Found the answer. Below is the example.
Router#ping
Protocol [ip]:
Target IP address: 10.1.1.1
Repeat count [5]: 100
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: Serial0/0
Type of service [0]: 2
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]: Verbose
Loose, Strict, Record, Timestamp, Verbose[V]:
Sweep range of sizes [n]:
Sending 100, 100-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
Packet sent with a source address of 10.1.1.2
Reply to request 0 (12 ms)
Reply to request 1 (8 ms)
Reply to request 2 (12 ms)
Reply to request 3 (8 ms)
Reply to request 4 (12 ms)
Reply to request 5 (8 ms)
Reply to request 6 (8 ms)
Reply to request 7 (12 ms)
Reply to request 8 (8 ms)
Reply to request 9 (8 ms)
Reply to request 10 (8 ms)
Reply to request 11 (8 ms)
Reply to request 12 (12 ms)
ping option,of course has lots off parameter
Didn't get you, how is this output different to the normal ping in IOS ?
