Ping Q's
Hi all,
I have some Ping Q's..
What switch must I use to show the packet loss percentages on each ping request?
What are the ping swithces for cisco routers(ie ping -s, ping -a, etc) and what do they do? For example, how can I increase the size by using a switch, etc.
What key combination can cancel a ping request?
Hall of Fame Super Bronze
Re: Ping Q's
1) You don't need a switch for loss %. Information is given by default at the end of the ping.
2) The following are the switches available in IOS
data ........... specify data pattern
df-bit ......... enable do not fragment bit in IP header
repeat ......... specify repeat count
size .......... specify datagram size
source ......... specify source address or name
timeout ........ specify timeout interval
validate ........ validate reply data
Example,
ping 2.2.2.2 data FFFF df-bit repeat 100 size 1500 source s1/0 timeout 5 validate
3) You can cancel a ping by hitting CRTL+SHIT+6
HTH,
Re: Ping Q's
Thats perfect, thanks a lot
487
