Purple
ping response
Haven't seen this one before . When i ping a device with greather than 200 byte packets, i get the following. What does the "Q" mean? Usually failed pings just get a "." reply.
Sending 2000, 1000-byte ICMP Echos to 10.33.3.22, timeout is 2 seconds:
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!QQQQQQQQQQQQQQQQQQQQQQQQQQQ
QQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQ
QQ!QQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQ
1 ACCEPTED SOLUTION
Re: ping response
Re: ping response
Purple
Re: ping response
Thanks , just have never run into or seen that one before . Thanks for the timely answer.
Community Member
Re: ping response
Q means source quench:
the Source Quench is an Internet Control Message Protocol message which requests the sender to decrease the traffic rate of messages to a router or host. This message may be generated if the router or host does not have sufficient buffer space to process the request, or may occur if the router or host's buffer is approaching its limit.
brgds
TS
1212
