PIX 501 & 506 PDM Question
I have a question regarding the PIX 501 and 506e using PDM. When I first set up the device I am able to connect through PDM using the default settings, however when I change the internal IP interface and configure the laptop I?m using to utilize that network I am no longer able to connect using PDM. In order to gain access again, I have to unplug the firewall so it resets to factory settings. Thanks for any help in advance!
Greg
Hall of Fame Super Blue
Re: PIX 501 & 506 PDM Question
Hi Greg
Try adding to the config
http "your new IP address" 255.255.255.255 inside"
You need to allow your internal IP address to have access.
Jon
try
http 0.0.0.0 0.0.0.0 inside
telnet 0.0.0.0 0.0.0.0 inside
or per subnet
http 192.168.1.0 255.255.255.0 inside
telnet 192.168.1.0 255.255.255.0 inside
This way you are not bound to your IP only accesing the pix, you can now access it from any inside subnet.
Jorge
250
