PIX 501 and Internet Access
otnj2ee
My network is very simple, like this: A DSL Modem is connected to a Cisco PIX 501 firewall/router, and a computer is connected to this firewall.
Now this PIX 501 box has two interfaces: Inside (192.168.1.1) and the netwroked PC (192.168.1.2). The outside interface is set to DHCP to be dynamically assigned an IP by the ISP's DNS server (192.168.0.1).
My networked PC (running Windows XP) is configured with an static IP (192.168.1.2), default Gateway (192.168.1.1 which is the PIX 501), and the DNS IP (192.168.0.1 which is the ISP's DNS Server).
But I can NOT access the internet. I can Ping 192.168.1.1 (the inside interface) but not the outside (192.168.0.1).
What am I missing and what should I do?
Scott
m-haddad
Level 5
Level 5
Did you configure nat on the PIX?
You need to add the below:
Global (outside) 1 interface
nat (inside) 1 192.168.1.0 255.255.255.0
Remark: Try to use a public DNS such as 62.84.64.3
Let me know if this solves your issue,
Appreciate your rating,
jmistich
Scott,
You will have to setup NAT so that all packets going from inside to outside get translated.
John
CCIE 7536
